Posts: 2,097 |
I did spec flywheel, stage 2 and quaife w/ reline fluid, and rebuilt 2000 tranny...love it
98 E0 SVT with some stuff
Posts: 469 |
My tranny is in the shop as we speak being rebuilt. I am adding a Quaife, Spec Stage II clutch, Unorthodox Flywheel, thoes motor mount polyurethane inserts, and some new ground controls  . I will let u know how i like it all once i can test the new set up out.
Contour is SOLD
97 GST eclipse is SOLD
2002 S2K...
Posts: 5,854 |
Got a spec stage 2, quaife, and lightened svt flywheel installed around this time last year.
Clutch - very smooth, but bites really good. Still fine after about 20k miles
Quaife - definitley better handling while driving agressively. Worth it for the performance, but driveability is pretty much the same. Definitley helps in the snow though.
Flywheel - Again, nothing much different from stock, but 1st gear goes by way fast now. Also, don't have to downshift as much on the highway, when passing and stuff.
All the mods were worth the money. Especially because they didn't make the car any harder to drive...but you still get the performance.
1999 Silver Frost SVT
#609 of 2760
Posts: 3,570 |
Originally posted by TheGreatOne: Flywheel - Again, nothing much different from stock, but 1st gear goes by way fast now. Also, don't have to downshift as much on the highway, when passing and stuff.
Heh, just imagine what that would've been like with a Fidanza, which is about 75% less weight than that lighter SVT flywheel I pass cars in 4th and 5th gear regularly now. It even made a difference in my top end, I bury the speedo with ease now
Posts: 536 |
I want to get a lighter fly wheel, but what I read, dident sound good. It sounded like there would be a big loss of drivability. Is this true? My plan is to get a Terry Haines with a Qualife. I think I want to stay with the SVT clutch, it seem good, and I dont want chater. What do you think I should go with flywheel wise? Thanks.
99' SVT #811 of 2760
Born on january, 12, 1999.
"This may have been his only shot at number one, but he just sucks on so many levels that I couldnā??t even let him win a contest of suckiness."
Posts: 9,602 |
Originally posted by Daddy Phat Sacks: Originally posted by DemonSVT: I love everything I did.
Wow. thanks, You guys are very helpfull. thanks anyways guys.
I figured you could see my profile or site but I get the picture...
Torsen Limited Slip Differential Spec Lightened Billet Aluminum Flywheel (7.9lbs) Spec Clutch and Upgraded Pressure Plate All Upgraded Shifter Forks & Syncros XS4Z Upgraded Shifter Tower B&M Edge Short Throw Shifter (disconnected centering spring) Urethane Casting (94 Shore Hardness) Filled Transmission Roll Resistors (Front & Rear)
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 3,570 |
Originally posted by Daddy Phat Sacks: I want to get a lighter fly wheel, but what I read, dident sound good. It sounded like there would be a big loss of drivability. Is this true?
Nope. I mean, well, it IS easier to stall the car, yes, but it's really not a big deal. After upgrading to the fidanza, I've maybe stalled my car ONCE because of it. So I can't really say there's a drivability problem there. All other changes that are a result of it are good changes, mainly how fast the car rips through 1st and 2nd gear now, how much faster the revs climb, and the awesome throttle response.
I don't see how you can loose with the fidanza. Although some have had problems getting clutches to mate with them well. I didn't really have a problem with it, but I had the steal insert of the fidanza machined so it would help the break-in process. Seems to have worked well as I don't have any problems besides a little bit of chatter at idle, but thats because of my clutch design, not a flywheel problem.
Posts: 536 |
Originally posted by DemonSVT: Originally posted by Daddy Phat Sacks: Originally posted by DemonSVT: I love everything I did.
yeah sry I am an ass! I figured it out later. sry man.
Posts: 7,100 |
Originally posted by rkneeshaw: All other changes that are a result of it are good changes, mainly how fast the car rips through 1st and 2nd gear now, how much faster the revs climb, and the awesome throttle response.
I think he was referring to being concerned (as well as I am) with the increased vibration that would be felt throughout the block, going in a completely different direction than a DMD. Since the harmonics of this engine seem to be a very big topic of conversation, I would assume increased vibration would be the opposite of what I would want to do..
my .02
Ray
'99 CSVT - Silver #222/276
Posts: 2,483 |
Quaife, a lightened flywheel, and a full rebuild with all new/upgraded parts. Its a thing of beauty!
Being a Zetec, I didn't need a heavy duty clutch, stock works just fine.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
