Posts: 5,143 |
Both stock, CSVT has the 5 speed, Grand Prix has the auto. Which would win? BTW the GT has the 3.8L V-6 engine. I think it pushes 200 Horsepower
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 6,760 |
very slight advantage goes tot he CSVT if it has a good driver......saw a GT at the track last night with a dial in of 15.5
Ryan
Trollin!
Posts: 1,506 |
CSVT by a hair... but be ready for blowing the differential.
MSDS, SHO-shop Y, custom 2.5" catback; xcal2; 63mm TB, K&N 3530; Koni struts, Aussie bar; THaines forks, Quaife, SpecII, UR fly; DMD; Nima UD pullies; Stazi brakes; f&r Pole120 mounts. Just a daily commuter car. Silver '98 SVT E0 #3159
Posts: 9,602 |
SVT easily.
The GT "should" beat it out of the hole but after 30mph the SVT walks it badly.
"Bench" racing the SVT is nearly a second faster in the 1/4 mile. That's a ton of car lengths or not even remotely close at the end.
In an "illegal" stop light battle the GPGT would be tough because it's brainless to launch and has a lot more torque for only a couple hundred pounds more weight.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 3,840 |
That's a lot of confidence you have there in making such a bold statement.  Anyway, a CSVT wouldn't likely romp and stomp a Grand Prix GT, but it would likely pull ahead once the revs build. Run into a supercharged GTP, though, and you better start saying your prayers.
Troll. 1997 VW Jetta MkIII GLS 5spd
All hail my appearance on CEG!
Posts: 1,346 |
yep
E1 CSVT
s/c-----x
turbo---x
3L------check
Posts: 9,602 |
Originally posted by SAV-ZX2: That's a lot of confidence you have there in making such a bold statement.
You are not serious right.
Yes the GTP should win "bench racing" (as I have beaten them stock for stock way back when) but it would be close.
Also the newer GTP's are heavier so they are not as quick as the older models.
Also the GTP still runs into a wall once moving. From a roll advantage SVT.
Then once you consider roads have turns it becomes 100% advantage to the SVT verses the couch with the durable 30 year old Buick engine. (Go Buick! )
2000 SVT #674
Posts: 7,392 |
a csvt will put a beating on a GP GT. trust me. i smoked one today.... at the track of course.
.....______
___|______\_____
|/-\_________/-\_|
.\_/...............\_/
CEG road warrior
CEG road warrior
Posts: 17,248 |
I thought we were talking stock for stock......in that case I have been reading up on Grand Ams (My G/F has a 2000 with the 3.4L) and there are people running high to mid 14's with intake, header, and exhaust.....fast as or faster than most CSVTs (3.0L not included).
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 79 |
i raced one the other day at the track.  you will have no worries after 60.
P2 91 tsi awd, not stock
P3 98 CSVT, stock
