i found a true cai kit on custom cougars for a 2.5 duratec, but i don't know if it will fit in my 2000 mystique with a manual because of the engine bay size. are the bays the exact same as the cougar?
http://www.customcougars.com/performance/images/DSC03579.jpghere is the information on it:
Description:
Introducing a TRUE Cold Air Intake for both the Manual and Automatic Transmission Cougars. The Cold Air intake will eliminate heatsoak, as your filter element will be located inside the bumper behind the foglight area. This area is shielded from water on all sides by the mudguards.
The CC Cold Air Kit comes complete with ALL Polished Tubing and Couplers by Hose Techniques for COMPLETE replacement of your stock air intake or existing aftermarket intake. The Purchase of hose fasteners may be needed.
This intake is Not a simple bolt on piece. You will be required to do some modification in order for this system to fit properly. Just like Ground Control, if you want the best you have to do some cutting. Please see below for needed modifications.
Installation Information:
Those with a Manual Transmission :
You will have to relocate your fuse box to under the battery. This is easy and instructions will be provided. You will also need to drill a 3.5" hole for the piping to pass through to go behind the foglight. Again, detailed instructions will be included as well as provide a list of all tools needed.
Average Install time is 60-90 with a level 3 of install difficulty.
Install Difficulty Scale 1-5, 1 is the easiest and 5 is the hardest.
Shipping Information:
Item usually ships out in 2-3 business days. Method of shipping is USPS (www.usps.com) Ground Shipping with Delivery Confirmation. Shipping to Alaska, Hawaii or International Orders are subject to delay.
Ordering Information:
Product Price: $149.99
Shipping Price: FREE
i'm new to the engine upgrading stage so i was just wonering. if it works it seems like a really good deal.
