Page 5 of 6 1 2 3 4 5 6
Stazi Offline OP
You are in the second batch. I am just waiting on the bushings which I shuld have in a few days.
Please note - EVERYONE - My email for PayPal payments has changed to:
anastazi.sarigiannis@skf.com
Stazi Offline OP
The second batch of 10 sets of endlinks will go out today.
Thanks,
Stazi
Staz,
Did you get the MO for the links?
Allyn 48
98 SVT T-Red. 17" Borbets w/GY Eagle F1 GS-D3's, Koni/Eibach setup, urethane suspension bushings. Aussie Bar. Battery in trunk, open K&N Filter. B&M Shifter. Gauge pod w/ volts, oil pressure, oil temp. Sparco drivers seat, Schroth harness belt
I received mine today. They look real nice, can't wait to put em on.
Got my links today.
So I will ask this one more time, do I need to renforce my bushing mounts for the BAT rear sway bar.
SVT Spec. (21mm I think)
Just a yes or no ansewer from Stazi would be great.
Thanks
got mine today, VERY PIMP, very nice, thanks Stazi. . .
got mine yesterday...look great, thanks Stazi
Scott
Scott 2000 Contour SVT #1464 Mustang Dyno: 171.6hp/145.3lb Dynojet Dyno: 171.1hp/148.9lb 1989 20th Anniversary Turbo T/A "Indy 500 Pace Car" #1376 of 1550 All Original, 46k with a few mods 2002 F150 SuperCrew
Got mine yesterday too. They're so nice, I'm thinking I might show them off & mount them on the dash... nah.
Seriously, nice product Stazi! Mine will be installed tonight.
Stazi Offline OP
Yes, you should install new swaybar bushings with the larger sway bar(you'll have too anyway cos the bar is larger and the stock bushings don't work), but I would go ahead and beef up the backing plates with thicker and longer plates (two add a second mounting hole) and upgrade to Prothane brackets that use the two-hole mounts, rather than try and finagle the crummy stock "one hole and tab" bracket to work - it won't last!
Also you may find that you will need to get 2 new 3/8" Stainless Steel through bolts for the end link to sway bar connection, as a CEG'er told me that his stock sway bar bolts (that go through the stock endlinks) are a pinch too big for the upgraded links. This is weird cos a prototype I made with 7/16" rod end ended up needing me to drillout the sway bar eyelet to accept the larger bolt, so I though the next size down would do the trick. It's not a big issue, so don't fret.
Also, a tip on installing them to make it a LOT easier for you is to use ramps instead of axle stands to elevate the rear of the car. This will keep the lower control arms loaded, and parallel to the ground and thus easier to connect to the sway bar.
Another thing you can do is slather on some marine wheel bearing grease onto the spherical ball when you're all said and done to keep it lubricated and stop it from corroding (yes, even stainless steel corrodes!)
Thanks for the kind words guys!
Thank you for info. The links look great.
Moderated by  1314_dup1
