Posts: 1,325 |
Well, I know there repuation leaves MUCH to be desired, but I was (am?) going to give sho shop a shot at some of my business. Well, that is if they ever decide to answer the phone. I've tried 4 times over the last three hours and it always rings and rings and rings...
Doesn't bode well for my order if they don't even answer the phone to take peoples money - I'd imagine if something goes bad you never get a refund
Are they like closed on Wednesdays or something silly?
97 Contour SE MTX
04 Grand Caravan SXT
Posts: 96 |
you might try to contact evosport, as it is owned/ran by vadim and the place is right next door to the sho shop from what i understand. http://www.evosport.com/home.html
93 ATX SHO
Intrax Springs/Bondourant struts
Front & Rear STB
Subframe connectors
SHO SHOP y-pipe and flexpipe
75mm Pro-Flow MAF
K & N Filter
Posts: 536 |
BAT offers alot of the same things, or so i have heard. But the shiping might be a beeatch.
99' SVT #811 of 2760
Born on january, 12, 1999.
"This may have been his only shot at number one, but he just sucks on so many levels that I couldnā??t even let him win a contest of suckiness."
Posts: 1,325 |
Since I'm in San Diego shipping would be way better from Sho - I could drive there in under 2 hours so even with ground shipping it'd take a day or two tops.
Plus I wanted there y-pipe specifically so I can do a on / off road combo deal for CA emissions checks.
97 Contour SE MTX
Posts: 6,760 |
SHOShop is only a web business now. Evosport has flowed over into where SHOShop used to be located. Leave a message and most likely Vadim will call you back tonight.
If the things you want you can get else where, I would do that. And I'm speaking from experience.
Ryan
Trollin!
Posts: 9,602 |
Originally posted by Daddy Phat Sacks: BAT offers alot of the same things, or so i have heard. But the shiping might be a beeatch.
BAT is located in Florida if you did not know...
I do agree BAT is a much better choice "IF" they offer the same part.
The ONLY thing SHOShop alone offers that is worth getting from them is the UD P/S pulley.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,325 |
Does anyone else sell an off road y that you can bolt a cat onto as well?
97 Contour SE MTX
