I have checked the "mesh grille-work in progress post" but I am still not certain about how to install a mesh grille for Micah's pre 98 svt front bumper. I have read that some people use paper clips? What are they attatching the paper clips to? I have also read that others use black silicone. I already have my mesh grille and want to know the best way to install it. Any advice would be greatly appreciated.
Hot glue!! Works great and is easy to use.
-Matt
98 Silver Frost SVT Frostie
Will hot glue provide enough support and will it last long or will I have to continue to re-apply it. I am worried that hot glue might not hold when it rains.
I am Canuckian
I am Canuckian
I plan to use MARINE GOOP. It has worked so far on my clear corners. How did you do your fogs? I ended up useing the same goop to cement mine in place. I will do the grills soon. I also did the front top grill with Elky mesh though I plan to redo it as the is a slight gap at the bottom that I don't like. Are you going to do a different top grill. If so and you want some pics pm me and I can show you what I did. We really should meet up since you aren't to far from me. We could do the grills together.
Green 96 mystique gs 4cyl mtx 16.9 in the 1/4 mile @102500 miles 95SE in Midnight Red MTX MSDS headers and y-pipe SVT exhaust SVT UIM Optimized se TB. Full pre 98 SVT body kit 15.741 @ 87.73mph :)
Where did you get this Marine Goop? Is it similar to silicone? I haven't installed my fogs yet....still have to get bumper painted....I just want to prepare myself for the mesh grille install.
I'm assuming you just cut the mesh a little larger that the grille opening....fold it over from the inside and then use your adhesive....is this correct?
I am Canuckian
I am Canuckian
Well that is kind of what I am thinking for the mesh. As for the GOOP. I picked it up @ Home Depot.
