#937985 04/24/04 05:31 PM
se7en Offline OP
Is a focus (ZX3) head a direct bolt on to the contour(ZX1) block?
If so, is there a loss or gain in comp ratio? Would Piston crown Mod or replacement be necessary?, ie,piston to valve clearance issues?
Reason for the enquiry is the lack of ZX1 tuner parts(import at high cost) compared to ZX3 that has local tuner supprot and lower prices.
m.
#937986 04/25/04 09:49 PM
I
I
I don't think anyone here has tried a zx3 head package
but you could be the first
#937987 04/26/04 12:04 AM
A focus head should work. I am planning on using the FRPP Focus head. The only problem is the timing belt tensioner. The Contour uses a larger tensioner that sits in the center of the head. The Focus uses two smaller tensioners that sit below the cam gears.
I'm guessing that you may need to drill and tap new holes in the Focus/Escort head to get the Contour timing belt tensioner to work.
HTH,
BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies--- +++JRSC M62 Under Construction+++ My big-a$$ mod list.
#937988 04/26/04 08:56 AM
se7en Offline OP
thanks for the replies. It might be easier to use the Focus tensioners.
Let the project begin...
Edit: forgot about the waterpumps. Maybe the whole ZX3.
m.
#937989 04/26/04 02:33 PM
From what I've read around here a head from a ZX2 will work but not one from a focus. That is if you have a 98 plus car. I thought the issue was that both contours and ZX2s have the VCT. I am mis-understanding this?
#937990 04/26/04 10:46 PM
Only 98+ Contours have VCT. I think that only the SVT Foci have VCT. (I'm not 100% sure on that one.) I do know that the FRPP Focus head does have an EGR port.
BP
#937991 04/26/04 10:58 PM
ANyone know if the SVT Focus heads can bolt on to the regular Zetec? Sorry to hijack your thread.
Aaron
#937992 04/26/04 11:09 PM
Aaron
No.
2000 Contour SE 2.5L ATX - Toreador Red 2001 VW Golf GLS 2.0L MTX - Tornado Red Buy my possessed VCR!!
#937993 04/26/04 11:12 PM
All 2L Zetec heads/blocks will bolt together. Heck, you could even put a SPI head on your Contour if you wanted to. But who would want a pushrod 2L?
The things that made the SVT Focus Zetec special was a higher compression ratio, a performance exhaust header, and a special intake manifold with switchable runners.
BP
#937994 04/27/04 01:43 AM
I
I
and VVT
Moderated by  Loco4G63
