#93469 07/28/02 07:17 PM
Majitsu Offline OP
as we all know 4 gauge is a big wire and an svt contour is a little car anyone know where
the best place to run 4 gauge from the battery to inside the car is?
Majitsu
#93470 07/29/02 06:19 AM
H
H
Originally posted by Majitsu:
as we all know 4 gauge is a big wire and an svt contour is a little car anyone know where the best place to run 4 gauge from the battery to inside the car is?
On my non-SVT I ran my 4AWG to the right of the battery, around the strut tower, then down to a grommet on the driver's side of the firewall. From there, I routed the cable to the side plastic moulding right behind the hood release lever, then all the way back to the trunk.
All in all, it was a lot easier to run 4 gauge than I thought it would be. Just remember to use wire ties where appropriate.
#93471 07/30/02 09:18 PM
Majitsu Offline OP
do you have any pictures of how to do this? i cant seem to find the grommet that you
are talking about.
#93472 07/31/02 07:12 AM
I went the easiest way possible, though the factory frame rail holes wink You can get 1/0 through there if need be
#93473 07/31/02 12:32 PM
You can route the power wire into the cabin through the teardrop shaped hole, you just pop the black rubber thing out and punch a hole in it, then stick the wire through and put the rubber thing back in place (i'm not sure if all the contours have that hole available, but check the right side of the firewall). Once in the cabin, you can route the wire to the back by going underneath the black weather seals, i'm not sure how well it will fit though. Remember to use plastic wire loom to protect the wire in the engine bay, just to be safe. smile
#93474 07/31/02 12:35 PM
It's around your clutch and brake pedals. I used to have a picture on my server, but seem to have deleted it during a clean up. I'll see if I can grab another photo today.
#93475 07/31/02 01:51 PM
thanks. i could also use this info.
in a related question, if iam splitting power to 2 amps, is it better to place the distribution block closer to the battery or closer to the amps? or does it even matter?
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t
1974.5 MG B GT
#93476 07/31/02 02:07 PM
Doesn't really matter, better off to put it closer to the amps so you dont waste as much wire.
Joel Falkenberg
#93477 07/31/02 04:55 PM
2
2
IIRC, isn't there a part in place of the rubber grommet on an SVT?
2000 SE Sport V6
Deep Navy CC Metallic
My 2G Sport
#93478 07/31/02 05:32 PM
Here are the pics, both from the footwell. Sorry, I couldn't follow the cable all the way up but it definitely goes through an existing hole in the firewall. In case you're not too sure, it's the large red wire you're looking for.
Moderated by  dnewma04_dup1
