Page 2 of 2 1 2
#933699 09/17/04 07:29 PM
Probably IAC, mine does the same in the winter.
#933700 09/17/04 07:36 PM
should mine do it all the time tho? it does it everymorning year round....well i've just noticed it the past couple months...but its been summertime.
1998 Contour SE Zetec atx, intake, custom dual exhaust, ngk iridium plugs, 8mm wires, svt body kit, 17" motegi mr7's, b&g springs http://www.cardomain.com/memberpage/366279
#933701 09/17/04 08:57 PM
Also check your MAF.. Some people use spays, but I like to use a Q-tip and rubbing alcohol. Clean these wires like it was a surgen on your private parts because it's not cheap to replace.
While looking at the IAC, you might want to check out the other hoses down there. I've already replaced a few hoses that have melted a cracked
#933702 09/18/04 12:57 AM
mine used to do that, it was the power break booster hose on the manifold and it kinda swelled up which was causing it to lose vacuum makin it run for [censored].
2002 Cougar 2.5 duratec/ mtx-75 85,0000 Mondeo ST-200 wheels/BFG KDW NT black/black Spec Stage 1 Torsen T-2 Trubendz 2.5 flowmaster dual exaust apexi s-afc II K&N FIPK
#933703 09/19/04 05:02 PM
Where is the IAC on a '96 Zetec? I saw a picture where it was under the car (as opposed to another picture of the V6 which had it on top).
Thanks
****************** Kenneth Clark '96 Mystique GS Zetec ATX Pacific Green
#933704 09/19/04 08:06 PM
Under the car, from the engine to the firewall, on passenger side.
Page 2 of 2 1 2
