#933689 04/19/04 09:49 PM
I'm gonna clean the EGR valve. Is it self explanatory? Just remove and spray cleaner inside and let dry? Also, can I clean the IAC valve? Thanks.
#933690 04/19/04 10:16 PM
You will have to scrape the EGR valve. Don't use anything that will damage the valve seat or pintle. Do not get any strong chemicals up into the top where they can damage the rubber diaphragm.
Clean the IAC with carb cleaner and finish with silicone spray.
#933691 04/19/04 10:31 PM
So what should I use to scrape it? And I can't use carb cleaner on it?? And by silicone spray, do you mean like the same stuff I use to lubricate weather stripping with? Thanks, I hope this will fix my somewhat rough idle.
#933692 04/19/04 10:33 PM
If you do use the silicone lube, definately let it fully dry before installing. I have not had any problems as I let mine dry in the Florida sun while I did other maintenance, but others have indicated that silicone can damage O2 sensors.
If you don't use silicone lube - go without lubing it. Should be fine, otherwise you could also try some light machine oil - like for sewing machines.
#933693 04/19/04 10:46 PM
One more thing, should I get new gaskets for both of them?
#933694 04/19/04 11:35 PM
Z
Z
You can clean it?!?!?!?!
I replaced mine... 3 hours of work to get the stupid metal tube of the bottom! Almost cut a wrench down to make it work. Should have removed the intake manifold!
<Kidding>
Where is the IAC on this thing? Is that the other Silver can on top of the fuel rail?
'97 Mercury Mystique GS (Not mine anymore...) Now running a Toyota Matrix XR Red, 16" wheels, Sunroof, VVT-i
#933695 04/20/04 03:00 PM
That's your Fuel Pressure Regulator.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST Pre98 Zetec - Some Mods
#933696 04/23/04 10:14 PM
E
E
I just used the male end of a battery wire brush and scrubbed the hell out of it with that and it worked along with some brake cleaner (was out of carb cleaner)
95 Gl Zetec Atx
#933697 04/26/04 09:14 PM
Yes you should.
You don't HAVE to, but for $5 max, why the heck not?
#933698 09/17/04 07:19 PM
ok, i know this is a kinda old post...but i think i may need to clean my iac valve...when i start it up of the mornings..it will sputter and kinda act likes it going to die or somthing...and if i put it in reverse...it will get worse...but if i let it set for a minute or so...it will be alright...i just give it a lil gas and let it idle a second and im on my way...would this be what it is? if not then what is it and what can i do about it? thanx.
1998 Contour SE Zetec atx, intake, custom dual exhaust, ngk iridium plugs, 8mm wires, svt body kit, 17" motegi mr7's, b&g springs http://www.cardomain.com/memberpage/366279
