Page 2 of 2 1 2
#933606 04/21/04 05:33 PM
Z
Z
Originally posted by zaven:
Ok lets add to this just alittle bit so how many of you still have your factory clutch and how many miles are on it.
Been discussed a few times:
http://www.contour.org/ubbthreads/showthreaded.php?Cat=&Board=general&Number=482071&page=&view=&sb=5&o=&vc=1
- Zack WANTED: T-Red HEATED Side Mirrors FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps 2000 T-Red SVT 1995 LX V6 MTX (RIP)
#933607 04/22/04 01:45 AM
9
Originally posted by TexasRealtor:
Anyone ever have trouble getting their car in gear when stopped? It has no problem going into gear when moving or when the engine is off. But if I start it and try to put it into gear it is difficult. I can put it in 5th, then 3rd and fist it into 1st, but I have to turn off the car to get into reverse. This only happen about 50% of the time, sometimes it goes in gear without incident.
TR
2000 CSVT
Sounds like syncros. When was the last time you changed your tranny fluid? I put some Aamco synthetic ATF in mine, and it made a world of difference (e.g. Gear changes are smoother and if feels much more solid, and quieter). Give it a shot, it may solve your problem for now. Otherwise, when you change your clutch have your syncros checked out.
Sean
'99 Silver SVT Contour (2000 miles since June, now needs new front brakes and bearings) '98 CBR900RR Again (Put away for the winter)
#933608 04/24/04 07:06 PM
TR
2000 CSVT
Never, I just bought it about 5 months ago. It has 44,000k on it. I'll try changing the fluid. I read in the archives that I need to replace the old fluid with a new one(XT-M5-QS), which is "honey" colored instead of the original "reddish" fluid.
TR
"Eagles may soar high, but weasels don't get sucked into jet engines."
#933609 04/25/04 06:31 AM
9
That's the one. I would give that a try first. It's alot better than tearing the tranny apart!
Sean
P.S. I used the Aamco Synthetic ATF in mine, works pretty good.
Page 2 of 2 1 2
