Posts: 2,382 |
Originally posted by outkast: DO it!I have those gauges also and I stole Nates Idea of putting the switch in the dash looks so,so good
You stole my idea! Damn you!
"Fear is the little death."
Muadib.
Posts: 345 |
"I guess of all my uncles, I liked Uncle Cave Man the best. We called him Uncle Cave Man because he lived in a cave and because sometimes he'd eat one of us. Later on we found out he was a bear"
http://www.cardomain.com/ride/586498/1
Posts: 2,382 |
Originally posted by Nate'sTour: You stole my idea! Damn you!
That picture if you can't see it should be this
Muadib.
Posts: 802 |
![](/ubbthreads/images/graemlins/blackeye.gif) Sorry Nate!I had to do it
New Pics of OUTKAST 1!Sept2006
Posts: 2,382 |
No worries ![](/ubbthreads/images/graemlins/smile.gif) I still have one insert left that has nothing in it. I may put some gizmo there soon enough, but what?
Muadib.
Posts: 802 |
I have no space on my panel!I have a switch for the panel guages and pod.I,ll update pics soon.Check my link below.
Posts: 1,001 |
i just bought the same ones a month ago. ever since the install i haven't gotten it perfect. either the needles were a lil off, or the overlays rub on the needles. i've had the dash apart 6 times since then, taping, glueing and doing whatever i can to make them stick. good luck.
Posts: 2,382 |
Originally posted by dartsoccer8: i just bought the same ones a month ago. ever since the install i haven't gotten it perfect. either the needles were a lil off, or the overlays rub on the needles. i've had the dash apart 6 times since then, taping, glueing and doing whatever i can to make them stick. good luck.
You didn't take the needles off did you?
I used gorilla glue to hold mine down, and I had to go back twice as well. Since then, no problems.
Muadib.
Posts: 345 |
Originally posted by Nate'sTour: You didn't take the needles off did you?
So do when i put them on do i leave them on?
Posts: 4,155 |
You know guys, not to bump into the questions, I have one of my own however. Mine are agreeably beautiful I took them out however. Reason being is that they didn't match pretty with the mileage and it looked like a blue/green yellow/green hodgepodge of well...crap. Do you guys run with the interior lighting off or do you just deal with the missmatch?
Edit: Missmatch referring to the stock lighting in the gauge cluster leaking through
