Page 2 of 2 1 2
Z
Z
Originally posted by ContourSVTCobra:
I have a NOS kit with fogger nossle 125 shot with no computer tuning and no problems
You are probably running really lean! If you don't have anything done for enrichment or retard then you will run into problems if you are not carefull, when I was shooting a 75 shot I had to add 20% to my fuel curve to not be lean! Run it on a dyno with the juice and get an idea what A/F ratio you are running. Better to be safe than sorry.
98 Contour SE 3.0L 5-speed SCT PRP, Gutted IMRC's, Fidanza Flywheel, Race Ported 2004 3.0L Oval Port, Zex 125hp shot, 70mm Mustang TB, 42Lb injectors,Walbro 255 pump, Traction Bars, Zeitronix wideband o2, lots of little things, 10,000K HID's!!
I have been running a 75 shot for a few years now. I have around 75,000 miles and no problems. If you decide to run with a fogger set up I would advise not to push more than that. If you do not so fun things start to happen (personal experience prior to researching the subject). As for the 125 shot I would hope that it is on the Cobra part of his name not the Contour.
RVM Short Shifter RVM Intake Pipe Full Kenwood System NX Neons "If you can read this, thank a teacher; If you are reading this in english, thank a soldier"
I have 59xxx on my Svt and i am thinking about adding a 50 or 75 shot of ZEX. I am having the tranny rebuilt right now and i am adding a quaife, Spec StageII clutch, Spec flywheel, and motormount inserts. I think i will look more into this nitrous...
Contour is SOLD 97 GST eclipse is SOLD 2002 S2K...
F
F
Laughing gas is cool !!!
REDLINING IT ALL THE TIME 1998 mtx zetec contour 17.1 @79mph open element air filter ford 9mm racing wires dtm style exhaust
Page 2 of 2 1 2
