I
I
Hi everyone,
I just got an Auto Gauge tachometer. I am pretty much allset with hooking it up, except that I need to connect a GREEN wire (on my tach) to a tachometer source. Does anyone know the easiest way to get to it and how it looks? I've searched this forum and my Haynes Manual and couldn't find the exact answer. Also if I hook it up, will the stock tachometer work as well as the aftermarket one?
Thank you,
Igor
*** Acing Team *** --My Dead Contour-- *** Acing Team *** ----My New Ride----
The white wire with a black stripe going into the back of the gauge cluster is a tach signal.
04 Subaru WRX "Eurosport bling bling fast and furious tokyo drift" "They have diarrhea of the mouth, and constipation of thought"
I
I
I saw that white wire with a black stripe right around the fuse box. Is it possible that that is the wire I'm looking for? Because I couldn't get as high as the gauge cluster is...
Also, I think there's 2 of them....hmmm
Thanks,
Igor
I ran mine right to the ECU harness itself, and tapped the tach wire there. Wasn't hard at all...
I could've just done it behind the gauge cluster as said, but I didn't think of it when I installed it a few years back.
99 Cougar V6 MTX...Plenty of mods My best mod thus far: Trans: Brand New MTX-75 with B1 gear set, Quaife LSD, 4.5 Final Drive, Spec Stage 1 Clutch, Spec Aluminum Flywheel...
I
I
Well Thank you all, today I finally finished installing my tach. The hardest part was to find the white wire with a black stripe... there was at least 5 of them!! I tried each and every one of them... I was about to give up... finally with my 5th try I succeeded.
If anyone has a question on how to install a tach, you can ask me now... hehe
