Page 4 of 14 1 2 3 4 5 6 13 14
#932295 04/19/04 01:00 PM
hmm thats a good idea.
I sorta remember, but I also remember there is a bracket that I need to install for the box.
but if I just take the filter off and the ATI ACTI what ever that plug is in the filter and just blow dry it I'll try that. if not I'll have to actually remove and replace.
97 T-Red LX ATX pre98 CF SVT front,SVT rear/side skirts FSVT wheels Custom Front Ford Logo (body Colour) 35% tint all around with sun visor WP With Metal Impeller? Elky Grills CTA Intake CTA Custom Dual Exhaust
#932296 04/19/04 02:27 PM
what about a paint stripper dryer? would that be to hot?
being me and my dad we dont' hve a blow dryer
#932297 04/19/04 03:57 PM
I am Canuckian
I am Canuckian
Keith washed his engine bay at the pressure wash car wash. Does this change anything in terms of the water in his element? I mean the engine still runs so not a water lock issue right?
Green 96 mystique gs 4cyl mtx 16.9 in the 1/4 mile @102500 miles 95SE in Midnight Red MTX MSDS headers and y-pipe SVT exhaust SVT UIM Optimized se TB. Full pre 98 SVT body kit 15.741 @ 87.73mph :)
#932298 04/19/04 04:00 PM
I am Canuckian
I am Canuckian
On the up side the car was off. Any one else have any idea about the computer thought I had some posts back?
#932299 04/19/04 05:21 PM
someone suggested putting in some gasline antifreeze and doing a quick run to woodstock and back on the 401. hopefully that'd burn off the water?
#932300 04/19/04 07:46 PM
Your biggest problem is the water in the element/filter just get it dry. The rest of the engine will get hot enough to vaporize the remaining H2O. Mark you could be correct about the computer but I'm not leaning that way. There was a seperate computer for the NG and I'm not sure if we removed that. Could it be causing problems? Anyway I'm leaning towards the car needing time to adjust. If it was a true CEL it should come on regardless of the driving pattern, meaning it would come on during the first cycle. Perhaps I'm wrong but I think we can have a crack at it when we go to Corey's. How does this weekend sound?
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
#932301 04/19/04 07:47 PM
I'm home saturday
#932302 04/19/04 07:53 PM
I am Canuckian
I am Canuckian
That could work Rob. Let me double check first though.
#932303 04/19/04 08:01 PM
We will need some carb cleaner or TB cleaner to check for vacuum leaks. This could be a likely culprit and it's easy to check for. One of the vacuum lines could have been damaged when we moved them out of the way to do our soldering. Also a new PCV valve couldn't hurt and isn't to $$$. This may give us an excuse to do a UIM/LIM cleaning. Although we won't be able to check codes. Let me look into that. Meet at my place again??????
#932304 04/19/04 08:14 PM
haha define to much $$$
Moderated by  Gerald_dup1, mbb41_dup1
