#932173 04/18/04 11:32 AM
Bulldog Offline OP
It´s good to see that more cams are being developed for duratec:
http://www.pipercams.co.uk/NewPiperWeb/redesign/PiperCamFrames.html
Ford Mondeo GT mk1 sedan 1996 2.5L Duratec
#932174 04/18/04 01:05 PM
NICE.....whats the convesion to us dollars?
#932175 04/18/04 04:26 PM
Bulldog Offline OP
526.62$
#932176 04/18/04 04:57 PM
is that for 4 cams, 2, or each?
#932177 04/18/04 07:27 PM
Should be all 4 becuase it lists both the intake and exhaust valve closing rates. But it almost looks like a regrind. Not very aggresive at all. It doesnt look like they have the lifts registered right. Its put down to .369 but it says all lifts under a 1:1 rocker arm ratio. Which the duratec is 1:1.8.
Would be interesting to look into though. Even if the grinds are pretty mild. Atleast they are priced within reason
Ex-cat cams dealer. Today we do motor mounts.. Tommorow. Intake manifolds
#932178 04/19/04 03:23 AM
Is this the same ol' 4cyl duratec that all of the british cams are made for?
-06 GTO Torrid Red/M6 -98 LS with BPU -05 Honda Odyssey EX-L mv .zig ..\for\great\.justice
#932179 04/19/04 11:31 AM
Bulldog Offline OP
No..
I did take a snapshot of that page:
#932180 04/19/04 03:12 PM
how does that cam add hp, the duration on the intake, which doesn't list the primary and secondary valves duration. Plus the duration listed is the same as the seecondary duration on the SVT, and the exhaust duration is lower, the SVT exhaust duration is 262. so how does this increase hp, and as said above the rocker ratio is not correct either it should be 1:1.8, unless the duration happens sooner maybe not even then
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
#932181 04/19/04 03:42 PM
As said before primary and secondary valve opening/durations mean NOTHING. They are there for emissions only and a possible 100 rpm longer power band in either direction. Seat duration doesnt mean ANYTHING in the production of power either. Its the amount of meat under the seat that counts. A better number would be the 0.050 durations.
#932182 04/19/04 07:14 PM
oh ok thanx for setting me straigh i thought it was all about duration, im so dumb
