Page 2 of 2 1 2
Originally posted by MxRacerCam:
Originally posted by Kremithefrog:
Since he decided not to get the stuff, I'm gonna change the topic real quick. I think I may have asked this before, but can't remember. Anyways,,, can I tap into the remote wire for my indiglo gauges to run off of it , it will of course still be connected to my amp. Does it carry enough power to run the indiglos?
probably not. and you'd most likely be introducing some noise into the system as well. you could do it via relay if you really wanted to though.
I agree, the turn on circuit has very little voltage. Use another source and do it right
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
I'm trying to do away with having a switch. So I need a source wire that is only on when the car or headlights are on.
you won't need a switch if you use a relay.
Why cant you use the power wire to your original gauge lights? or use the the headlight switch? If you have foglamps it should be easy.
2000 SVT Black/Tan #1633/2150 (a few mods) Alpine: CDA-9835, MRV-F540, MRD-M550 PG: TANTRUM-X 6.5 COMP all around. Some people wear Superman pajamas. Superman wears Chuck Norris pajamas. CEL currently: Off
I have foglights,,, they're sitting right next to me. I tapped into a headlight wire originally, but it was the wrong wire,, I have nothing to test it with. Anyways a friend is supposed to help me soon...
Page 2 of 2 1 2
Moderated by  dnewma04_dup1
