#930682 04/16/04 02:17 PM
fuel guage doesn't work anyone know how to fix it
#930683 04/16/04 02:44 PM
N
N
Did you let the fuel level get too low? It could be a stuck float, bad float, or the gauge decided to bite the bullet. The easiest would probably be checking the float sense all you need to do is remove the back seat and you will see a black round rubber cover that is over the fuel pump. Pull the pump and check.
'95 Mystique ATX I4 2.0 134,000mi '96 Contour MTX I4 2.0 36,000mi My Rides
