#929986 04/15/04 02:24 PM
Anyone using an accusump on a SVT contour? Are you running a filter relocation kit with it? If you were going to run an accusump how would you do it? Could I pull of the oil cooler and run the derale cooler or a mocal cooler and then use a T fitting to run to the cooler and the accusump?
1999 3.0L Cougar: 220fwhp and 200tq 2003 VW Passat W8 with 4 Motion AWD http://www.cardomain.com/ride/300644 PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
#929987 04/15/04 05:36 PM
Rick Blackford is. Shaggy may be as well.
#929988 04/16/04 07:38 PM
The accusump can be plumbed in pretty much anywhere but be sure to put a one way valve in the line before the tee to stop the accusump backflowing.
