Posts: 3,944 |
Originally posted by ChattavegasSE: Basically, take the stock MAF and cut off the four screws in the four corners so it's a round tube, more or less. Then tighten the K&N 3530 straight to it. No muss, no fuss. Wait, slight muss, no MAF adapter.
I have to be honest... I have no idea how this thing would attach to your intake then. It's held in place mostly by the four MAF nuts and bolts, so with no rear attaching point, I don't see how it could work on your car.
Now, with my original design that I did, I had the bottom piece extend out to the tranny mount. Once there, it was bolted down using the two bolts that went there. I might be able to work something out using that design, but I just don't see how this one would fit.
Phillip Jackson
`98 Mystique LS
262K+ and counting...
ATX rebuilt @ 151K
Posts: 4,714 |
If it'll help, I can grab some pictures of my SHO Shop heatshield to show how they do it.
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 21,653 |
I like your heatshield unisys but for lazy folks ya'll can do what I do. I just get some foam board at the crafts store and cut pieces and make a heat shield. Takes maybe 5 minutes and it works pretty darn good. My shield actually extends from front of car to back. Using one piece then battery, then more foam, then filter/pipe, then foam, then strut tower. Only downside is the foam board gets soft after a few months and you gotta do it all over again, but like I said it only takes 5 minutes and it blocks heat probably better than aluminum. Ooo and it looks like crap.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 6,280 |
Originally posted by unisys12: Originally posted by ChattavegasSE: Basically, take the stock MAF and cut off the four screws in the four corners so it's a round tube, more or less. Then tighten the K&N 3530 straight to it. No muss, no fuss. Wait, slight muss, no MAF adapter.
Then I'll make it work! Just call me MacGuyver!!!
Jim!
Posts: 80 |
I have a BAT pipe and a BAT snorkle filter. Tell me what measurments you need.
Posts: 3,944 |
Originally posted by KaptonContour: I have a BAT pipe and a BAT snorkle filter. Tell me what measurments you need.
Basically, I need the measurement from the TB to point where the MAF and MAF adaptor meets. Just measure from the point i have in the picture above to the point where the MAF and MAF adaptor meets and I should be good.
Thanks a ton!
Phillip Jackson
`98 Mystique LS
ATX rebuilt @ 151K
Posts: 6,280 |
Hey Phil, sorry I'm a bum, but here's how I have my filter attached directly to the MAF: And some lil touch-ups:
Posts: 7,117 |
Um... You got a red-eye reduction setting for that camera?
And what's with the pink oil cap? How many HP for that?
(snicker, snicker)
Posts: 6,280 |
Posts: 3,570 |
Yo, what happened to our happy little heat sheild maker? Is there an update on this project? I'd still be very interested, its friggin hot out here lately, a heat sheild would pwn.
