Does anyone have dyno graphs from a 2.5L or a 3.0L Duratec comparing a 2.25" exhaust system to a 2.5" exhaust system? I know I have seen dyno graphs that show gains by switching to a 2.5" system, especially if you have headers installed, but I cant seem to locate any of the graphs.
Nikolas
Owner www.Draxas.com 15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
That's a rather broad request. Do you mean ANY system with 2.25" and ANY system with 2.5"? Assuming different mufflers are used and different placements, different gains will be had. Try brullen, they usually have graphs for their stuff. Wouldn't buy from them though...are you considering making a system for us perhaps?....
99 SVTC, T-Red, #652/2760-12.8.1998 Mother#@%@!* did I sound abstract? I hope it sounded more confusin than that!
Bassani=2.25"
Bosal=2.25"
Borla=2.25" to 2.5" in the rear (I heard)
Brullen=2.25 or 2.5in, I can't remember and I don't even know if they're made anymore.
Yo-Dude=2.5 or 3"
Stock SVT=2.25"
I'd be interesting in a comparo of ANY of those. So far I've only seen the bassani vs. borla, which was erratic at best.
Wow, those are all really 2.25"?? How do they get the gains out of them that they do by just making a system with different mufflers?....The stock SVT system is mandrel bent, so no real gains to be had there...replace the mufflers and res (or no res) and logic says you should be up there in the 6-8 whp gains they get from cat backs....something doesn't add up here...
Now I am beyond confused. I had no idea that these aftermarket systems were also made in the same 2.25" sizes. Which exhaust system will give me the most horsepower? Money is no issue, but I don't want to spend an outrageous amount for a few extra hp. I also don't care how loud it is, as long as it doesn't sound RICE. Should I just modify the stock exhaust? I have been considering new mufflers and no resonator on the stock setup or a trubendz borla system with no resonators. anybody have any good ideas on how to get the most power from the cat back. I will also be getting a y-pipe if that helps any. THANKS!
Originally posted by Who the F are You?:
does your family tree not have any branches on it?
99SVT 235hp @ 6550rpm 212tq @ 5350rpm
y pipe = good. I'm a little confused on the rest of the details right now also. Agreement around here is that Trubendz is the best bang for your buck, and they use 2.5". I say go with that and an optimized y.
Originally posted by ssmumich00:
Bassani=2.25"
Bosal=2.25"
Yo-Dude=2.5 or 3"
Stock SVT=2.25"
Borla either stays 2.25" or drops to 2" at the quasi duals.
Stock SVT drops to 2" at the quasi duals. Also the 2.25" piping has a 2" resonator on it.
(2" dual is still larger than 2.25" or 2.5" single BTW - so the 2.25" single pipe IS a restriction)
Bassani, Borla, Bosal, & Stock all used baffled mufflers. (I.E crap for performance)
I do not know if Brullen does???
Most of these setup's "gains" over stock could be had by the stock setup replacing the resonator and mufflers with straight through design units.
The stock setup would likely even out perform most of these then!
Yo-Dude/Tru-Bendz is the best bang for the buck by far in a pre-made setup.
Not only that but it is fairly customizable as well.
F
F
Brullen is 2.5" and drops down to 2.25 at the rear y split
straight through muffler design
For the 2.5L, 2.25 = 2.5" for most purposes.
I have looked at the 2.25 Bassani gains side by side with 2.5" SCA and Brullen...gains same across the rev-range within 1-2 HP. Average gains above 4K RPM same (about 6 HP) Peak gains same...SCA 6HP, Bassani 7HP, Brullen 10 HP...however, this is misleading because in the pre-Brullen comparo they did not go to redline and it was still gaining power. At the last point on the curve where both plots were present Brullen was at +7 HP.
These were all on a 2.5L SVT with intake mods but not headers. On a 3L or FI, I think 2.5" would be clearly better, MAYBE on a heavily modded 2.5 (but I doubt by much). Agree with Demon that if the stock SVT 2" resonator (the big prob) and mufflers were replaced with Magnaflows it would prob be comprable (as the stock mandrel piping and Y are fine) but I do not think this has been dyno documented.
1999 Amazon Green SVT Contour (#554/2760) "People demand freedom of speech as a compensation for the freedom of thought which they seldom use." -Soren Kierkegaard (as posted by Jato)
Bassani=2.25"
Bosal=2.25"
Yo-Dude=2.5 or 3"
Stock SVT=2.25"
Correction:
Brullen = 2.5 --> 2.25
Bosal = 2.5 --> ?
I didn't even now a 2.25" to 2.5" comparo existed. I'm interested in seeing it as well.
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
Moderated by  mbb41_dup1
