#926087 04/12/04 12:20 AM
H
hethj7 Offline OP
H
I can hear the motor running, but the antenna doesn't move up and down. I did a search here and came to the conclusion that I probably just need to replace the mast. But, until then, shouldn't I disconnect the motor so that it is not trying to run? Where is it located?
Jason 1998 Contour SVT 1990 Mustang 262 rwhp, 307 lb-ft 1997 Yamaha FZR 600 Rice Haters Club Member #244 Mustang Works
well uhhh it's where the antenna is.
'04 Cobra Convertable!!
H
hethj7 Offline OP
H
Guess that was a stupid question now that I read your post :new guy hides in shame:.
I guess what I really meant to ask is can I disconnect the motor for now, or does the signal from the antenna to the radio pass through the same harness? I want to still be able to use my radio.
Pardon me if any of this sounds too stupid. I actually am somewhat mechanical in nature, but I just got this SVT home tonight and don't know any of the specifics of it yet.
V
V
You can just disconnect the top plug on the antenna assy. until you get a replacement mast.
In the trunk, open up the trunk lining on the passenger side, and voila- the antenna assembly. On the assy, you'll see 2 connectors, one near the mast, and one near the motor. Disconnect the top plug (near the mast). I actually did try each of them separately, & both stopped the motor from whirring up & down. I don't know what each does on its own, though. Maybe an inline antenna amp?...
-Chuck Dienzo Black 98.5 E1 SVT #5022 of 6535 Born on March 16, 1998 "If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason."
H
hethj7 Offline OP
H
Thanks Chuck! That is exactly what I needed to know.
W
W
....and you get to replace the whole thing.....
2012 Lotus Evora --------- 95 Mystique MTX - GONE 395,000 Kms --------- Both Zetecs '97 Contour Mtx - stock - GONE
It's alright buddy!!!
Sometimes this board needs a little humor because some of our cars suck so bad!
H
hethj7 Offline OP
H
So, you don't think I can just replace the mast? Or am I not reading into you comments right?
KTPDave - Thanks for letting the Pulp Fiction boys put me in my place. I need that sometimes .
go in ebay and type in ford contour power antenna
