Posts: 383 |
The pads aren't supposed to be removing heat from the rotors, that's the rotor's job. Yes, heat does transfer from rotor to pad but that's not the likely cause of your "warping".
UNderstand that almost all "warped" rotors aren't warped at all, but they do have DTV (Disc Thickness Variation) due to hard spots that turn into high spots. Hard spots can come from [censored] material but they can also come from uneven pad material deposits on the rotor, to the point that friction varies from place to place around the rotor. More friction = more heat and it can be enough to cause localized changes in the material of the rotor. There's the hard spots. Those hard spots are self-perpetuating to the point that they cause DTV and then brake pulsing.
Turning a rotor rarely removes the hard spots. It just levels them...temporarily. They will return.
To avoid this issue otherwise known as "warping", you MUST season the rotors properly and you MUST bed the pads in properly so they don't smear or leave uneven deposits of material.
Pacific Green '96 Contour LX V6
â??98 GTP, light mods, 14.66/94
Calypso Green '92 Mustang LX coupe, 13.56/101
Crown Autocross Club 1999 Street Tire Champion, 2000/2001/2002 Street Modified Champion
KCR SCCA 2002 Solo II Street Modified Champion
Posts: 14 |
I realize that pads are not supposed to absorb any heat, but reality is that they do. I am on my second set of Raybestos rotors and find it hard to believe that they would use worse material than what comes from Ford. I have had warping problems with both sets of Raybestos rotors, but they are a known company that to my knowledge creates reasonable quality equipment. I realize that they are not top end, but they are far from cheap crap also.
What rotor and brake equipment would you suggest to prevent future problems?
'99 Contour LX
2.0L 4 Cyl
Everything Stock
Posts: 383 |
You managed to miss most of the point. I'm not saying your rotors are [censored]. I'm not saying your pads are [censored]. I'm saying the reason rotors "warp" is most often due to uneven pad material transfer.
I'm saying, to paraphrase and flesh out the picture, if you have "warped" discs, throw them out, because you can't permanently remove the problem. Then if you season the new rotors properly you avoid most metallurgical issues you might ever encounter. So season your new ones before hammering them.
Then if you bed the pads in properly you eliminate most of the reason for improper material transfer. So bed your new pads properly.
Then, treat them right...don't sit with your foot on the brake after a hard/long stop because that leads to material transfer issues. Don't overheat them because then the material can smear leading to transfer issues. And so on.
Posts: 103 |
Originally posted by Big Jim: If it only happens when braking, it is highly unliely that it is tires or worn steering parts.
My brother-in-law had the same problem with his '98 Contour. He replaced his RHS tie-rod and it went away. "Highly unlikely" doesn't mean impossible.
/Eric
Ottawa, Ontario, Canada
'96 Mystique GS, ATX
Posts: 103 |
Originally posted by TOURing: Is it possible that Warn Control Arm bushings may cause a noticeable play in brakeing?
Yes. It could also be a tie rod. Per my other (2nd) post on this, my brother-in-law cured the identical symptoms by replacing his RHS tie rod.
A competent mechanic will check alignment and tires as well as for play in the suspension mechanism. A bent drive axle can also cause 1st- and 2nd-order harmonics under braking. Basically anything that rotates, or keeps things in place that rotate, should be checked.
The rotors, though the most obvious culprit, shouldn't be the extent of your search for the problem.
/Eric
