Page 2 of 3 1 2 3
#92553 07/08/02 02:17 PM
Sorry, I thought the the 1002 was dual 4 ohm. In that case like dave said, stick with the 1001 "if your going to use blueprint". I think the sub will still perform well with only 150 watts; afterall I only have 30 watts more going to mine, and like I said, it sounded great.
Vinny " 2000 T-RED CSVT "
MODS: KKM
SHO-SHOP OFFROAD Y-PIPE
NO RES
#92554 07/08/02 03:07 PM
Originally posted by dnewma04:
You could try to find a 2ohm sub, or a DVC with 4 ohms per coil.
got recommendations? laugh
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
#92555 07/09/02 04:35 AM
how about the Audiobahn AWP210 ?
AWP210 COMPRESSION PISTON SUBWOOFER --COMMON FEATURES: 45oz. STRONTIUM MAGNETS, PHAT 1.75" EPMD RUBBER SURROUND, GLASS FIBER-HONEYCOMB COMPRESSION PLATFORM, 2" 4-LAYER ASV VOICE COIL, DUAL 4 OHM, 2 OHM OR 8 OHM OPERATION.
AWP210 FREQUENCY RESPONSE: 23Hz-500Hz, EFFICIENCY: 93.2 dB YOUR PRICE ONLY $109.95
or the Cerwin-Vega HED-10DVC ?
Subwoofer Specifications
Rec. Sealed Box Dims: 0.70 - 1.00 cu.ft.
Rec. Ported Box Dims: not recommended
Free Air Usage: not recommended
Sensitivity: 88 dB
Frequency Response: 20-500 Hz
Recommended RMS Power: 150W
Peak Power Handling: 300W
Impedance: dual 4 ohms
#92556 07/09/02 11:29 AM
I would rather see you get two 1001s witha 1 cubic foot box than an audiobahn or CV sub.
#92557 07/09/02 01:40 PM
dang - i was afraid you were going to say that! looking to save trunk space!! frown
are there any drivers out there that will fit the space requirements, have the 2Ohm load, and sound good?
How about the ADS ads 310rs??
The 10" bifilar, dual 4 ohm subwoofer incorporates a double stack magnet, narrow voice coil gaps, and deep drawn aluminum cone material to work in small as .5 cu. ft. Power handling is an impressive 600 watts (300 watts per coil). The low Q design and high efficiency, guarantees the 310rs.2 will out perform many 15" woofers.
#92558 07/09/02 02:21 PM
The a/d/s/ would be a good choice but requires close to 1 cu ft to perform at its best.
BTW, I think 150w would be more than enough to provide some nice bass.
#92559 07/09/02 02:30 PM
ok - cool smile
if it's not enough (not that i don't think it wouldn't be) i can always add another BP1001 smile
any ideas when their website will be "active" for ordering? confused
thanks again guys!
#92560 07/09/02 02:54 PM
Toadster,
You could try building a box like below. Where the extended sides suspend the sub box up in the air. It would only be 6" tall so you would still have full use of the floor and the fold down seat functionallity.
sorry for the bad drawing.
http://www.fototime.com/52BD456C13E21EF/standard.jpg
#92561 07/09/02 05:17 PM
already bought that subzone box - so i'll probably just do the BP1001
#92562 07/09/02 05:50 PM
ahhh...should have been paying attention. smile
Page 2 of 3 1 2 3
Moderated by  dnewma04_dup1
