Page 1 of 3 1 2 3
#92543 07/08/02 02:12 AM
so i'm getting that USA-6300 AMP 6 channels -
RMS @ 4 Ohms @ 12.9v input 50W x 4CH + 150x1 or 65x2
RMS @ 2 Ohms @12.9v input 75W x 4CH + 300x1 or 80x2
so should i get the BP1001 or BP1002 for this application? i'm guessing that if i just bridge the two channels into the BP1001 then i'll just have 300W to that... otherwise running 2 separate channels to the BP1002 (so 80W/VC) - which is better? i'd assume the prior...
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
#92544 07/08/02 02:56 AM
woohoo! just won the for my US Acoustics USA-6300 AMP for $122.50 !!!!
laugh
#92545 07/08/02 03:07 AM
If you bridge the last two channels to the 1001 it will be running at 4 ohms mono, in which case it will recieve 150 watts not 300. Am I right, or is there something I'm missing. The 1001 is a single voice coil. However, if this is the case, it should still sound good. Right now I have 180 watts going to mine, and it sounded great.
Vinny " 2000 T-RED CSVT "
MODS: KKM
SHO-SHOP OFFROAD Y-PIPE
NO RES
#92546 07/08/02 03:43 AM
doh! so how can i get it to 2Ohms? so i can get the 300W?
#92547 07/08/02 04:30 AM
I'm not sure if I remember correctly, but if the 1002 is dual voice coil, you can get that one instead of the 1001. But right about now, I don't know if we're ever getting any new drivers from them. LOL
MODS: KKM
NO RES
#92548 07/08/02 06:02 AM
so with the DVC i can wire it up to give a 2Ohm load?
it's been a LONG time since i've played with physics.... frown
#92549 07/08/02 06:35 AM
Sure can
MODS: KKM
NO RES
#92550 07/08/02 12:20 PM
Its a DVC with 2 ohms per VC. Either a 1 ohm or a 4 ohm load is possible. I would stick with the 1001.
#92551 07/08/02 01:54 PM
so i've been searching the forums (ALOT!) on this subject - how does one get to the 2 Ohm number? it seems that everyone gets the 1 Ohm / 4 Ohm deal frown
also, on the blueprint site - it says the BP1002 is a 1.5 Ohm/VC sub... does that make a difference? (the .5 that is smile )
#92552 07/08/02 01:58 PM
You could try to find a 2ohm sub, or a DVC with 4 ohms per coil.
The BP1002 has a Resistance of 1.5 ohms but the impedance is 2 ohms per coil.
Page 1 of 3 1 2 3
Moderated by  dnewma04_dup1
