I need to know how to hook my power antena To my Custom Pioneer ...I know it is supposed to Hook up to the REMOTE wire but i am going to use that for my AMP and also the Wire from my stock radio for my power antena has a Weird Looking hookup . Please help Chris [email]PimpinAintEZ85 @aol.com[/email]
there should be a remote antenna wire from the pioneer deck. Should be blue, or blue with white stripe? not too sure, but that goes to the power antenna. Connect the power with a distribution block, and ground it. should be set. Hope this helps! Ren
DBZjunior what are you talking about. Pioneer head units only have one wire for both amplifier turn on and power antenna. It is a blue with a white stripe. If you are good with relays you can use a relay for the separation but you don't have to. I have a Pioneer DEH-P9300, I use that same wire to work my power antenna as well as 4 amplifiers. So I know that it will work.
