Posts: 504 |
Originally posted by Bullet: Maybe he's driving a Ford Festiva.
lol, a guy i work with drives one. We all call it the ford fajita
"Here's a mirror, see your stupid face!"
Posts: 2,039 |
Originally posted by T.B.: what the hell i ran a 16.5 the car is supposed to be runnin 15s is that with out anything in the trunk or passenger area cus all i had was the spare and sum gatorade to drin k at the strip any info would be great
If you drive as horribly as you type, I'd say you need practice in both.
-J
'98 4Runner
No life but CEG
No life but CEG
Posts: 1,539 |
Originally posted by contourGL1996: Originally posted by Bullet: Maybe he's driving a Ford Festiva.
LAMO
R.I.P: 95 Tour LX
working on getting
SVT Power!
SELLING 3L LIM AND UIM W/ TB!!!
PM ME....
Posts: 5,143 |
if you have a sitck man, you can expect it to get full perfomance out of regular shifting, you have to take your shifting to the max man. Usually the main thing to slow times down is the flywheel, because your engine needs to jump back down a couple thousand RPM's when shifting. I know with my 96GL on the 2.0L Zetec it takes a second before the RPM's are dropped down, which is normal on pratically all stock 4 cylender engines.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 1 |
Yea, a friend and I saw you run your car, I think. If you ran at Capitol like 2 weeks ago. We were looking for you because he drives a 2000 SVTC, maybe you let the revs drop too much inbetween shifts... what did you launch at also?
Posts: 331 |
Originally posted by LoCoZ: Originally posted by Bullet: Maybe he's driving a Ford Festiva.
Or a Zetec Contour!
If he had a zetec he'd be jumpin for joy
99 Zetec Atx Se
17's w/yoko H4 rubber
Green and Black interior
CTA + header + big pipes = very loud
89 Mustang LX (stock for now)
Posts: 200 |
What kind of tires do you have? What pressure are they at? And what rpm are you letting the clutch out at? I only have the SE 2.5  and I am in the high 14's without my juice. I dropped my tire pressures to 26psi and let the clutch out at 1500rpm, much better than my previous 2500rpm launches! Saved over 3/10ths by doing that! Fidanza flywheels help your engine rev up and down much quicker too. (as per previous post)
98 Contour SE 3.0L 5-speed
SCT PRP, Gutted IMRC's, Fidanza Flywheel, Race Ported 2004 3.0L Oval Port, Zex 125hp shot, 70mm Mustang TB, 42Lb injectors,Walbro 255 pump, Traction Bars, Zeitronix wideband o2, lots of little things, 10,000K HID's!!
Posts: 5,975 |
Originally posted by JVT: Originally posted by T.B.: what the hell i ran a 16.5 the car is supposed to be runnin 15s is that with out anything in the trunk or passenger area cus all i had was the spare and sum gatorade to drin k at the strip any info would be great
-J
LOL!
I'd have to say either there is something wrong with your car and/or you are not a very good shifter (no offense).
My first time at the track I was running 15.5s all day long in 90 degree weather and almost 100% humidity.
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
I'd say he probably babied it on the launch!
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
