#923742 04/09/04 12:29 AM
Do you have to drop the rear subframe to do the install. Is there anything else I should know before I get into it.
F
F
No need to drop the subframe.
Jack the rear end up and stick it on jack-stands
Remove both wheels
Unbolt end links
Unbolt mounts, remove brackets
With a buddy, one of you stay under the car while the other pushes it out from the side wheel well. underneath guy will guide it out while side guy pushes.
When going to a larger bar, it will take some work but you can wedge it into its home using the twom man methond above without loosening the fuel tank support brackets.
One of the easiest things to do ever. Just remove and replace.
Thanks. when you say wedge it in you mean getting it past the heatsheld?
Correct
T-red E0 SVT ATS 17x7.5 Comp Lites, 215/45/17 Falken 512s, Ausi Bar, Boxed subframe, Poli all around, Warmonger's Opt Y, Opt TB, AFE, DMD, NGK's, Bendix Ti, Alpine, Polk, Mobil-1 0W-40, Redline MTL.
