#92334 07/04/02 12:38 AM
I've got a alumapro 8" sub (damn good speaker) that I will custom install into the rear deck with a sealed enclosure I believe it is 200rms 250peak and I'm thinking about running a kenwood amp that is bridgable to 380x1 @ 4 ohm is this a ok combination or just plain insane?
2000 SVT #1633/2150 many mods, many more to come http://www2.gvsu.edu/~hafnerb/11h/car.jpg
"If it doesn't fit, force it, if it breaks, it wasn't meant to fit in the first place."
Which do you like better? Speaker or Amp?
The one you like better, you need to buy a component that will match up.
Ride: 2000 T-red SE
Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE
Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
You should be ok, but you will have to be careful when adjusting the gain.
The more power the better:). keep the gain low and you'll get cleaner sound than buying a amp and have to crank the gain and get distortion
Joel Falkenberg
Too much power is the only way you can blow speakers. Too much isn't always the best scenario.
The ONLY way to blow speakers? Under powering can also "blow" your speakers. And by the more power the better, i meaning realisticly, not like putting 1000watts rms to a 100 watt sub. But usually the more the better since you can turn the gain down and get less distortion.
Joel Falkenberg
2
2
And also keep in mind that the Kenwood is probably rated at 14.4V.
2000 SE Sport V6
Deep Navy CC Metallic
My 2G Sport
It depends on what ohm rating the sub is. If it is a different ohm rating you won't get the full power out of the amp. Chances are you are not getting 380watts to the sub.
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
Don't argue with Dave, it always results in Dave making people look like idiots laugh Clipping and distortion will not affect the speaker unless it is getting too much power supplied to it, otherwise it will do no damage to the speaker. Clipping and distortion might affect the amp but not your speakers (again, unless there is too much power being supplied) smile
Clipping heats up the speakers voice coil, and will eventually open it up. So underpowering a speaker MAY blow it.
Joel Falkenberg
Moderated by  dnewma04_dup1
