Page 2 of 2 1 2
It is not underpowering the speaker that "blows" it, it is either sending too much power to the driver, or sending a clipped signal (for an extended period of time) to a driver that will cause failure. Ususally, though, if one has an amp with too little rated power, they end up trying to push more out of the amp than can be done cleanly, thus sending a square wave to the sub. Correct ME if I'M wrong.
Mushu's pretty cool too!
98 Black/Blue SVT
#3829 of 6535
ummm yeah, I didn't mean to make you guys get all pissy with eachother. LoCo, the speaker is rated at 4ohm and the amp bridged at 4ohm is rated at 380watts so I'm just kind of waiting for a unanimous decision on if I should buy the kenwood amp or not.
2000 SVT #1633/2150 many mods, many more to come http://www2.gvsu.edu/~hafnerb/11h/car.jpg
"If it doesn't fit, force it, if it breaks, it wasn't meant to fit in the first place."
Originally posted by ARJoel:
Clipping heats up the speakers voice coil, and will eventually open it up. So underpowering a speaker MAY blow it.
Clipping causes an amp to put out up to 2x its rated power, which leads to overpowering, which leads to exceeding mechanical and thermal limits.
You could run a 100w amp fully clipped to a 300w sub forever with no damage.
Underpowering will never blow a speaker. User error, not adjusting the power according to the box being used, not setting gains correctly, etc will all blow speakers, but in the end, all of them will be caused by exceeding mechanical and thermal limits.
Page 2 of 2 1 2
Moderated by  dnewma04_dup1
