This 5x7/6x8 component set:
Specs:
Nominal Size 5 x 7"
Recommended Amplifier Power 20-275 watts
Nominal Impedance 4 ohms
Frequency Response (3dB in car) 50-20kHz
Sensitivity (1 watt (2.83v) at 1m) 90dB
System Type 2-way
Joel Falkenberg
how much? cant tell you if its a good deal without that wink
$400 Canadian
Joel Falkenberg
They ROCK. I own the RC620s, the RC820s are a close cousin, but they're a drop-in fit for the Contour. Mount the tweeters on the door sails (tip: order replacement door sails NOW, while they're still relatively cheap) and angle them so that they cross just behind the rearview mirror for good imaging. The crossovers will fit behind the glove box so that they're easy to adjust. Oh, one caveat: you need at least 20W RMS to wake these puppies up, 40 watts or more per channel is ideal.
Specs:
Nominal Size 5 x 7"
System Type 2-way
1999 SVT TRed/Tan. Upgrades: Pioneer DEH-9300 head unit, 6 disc changer (under passenger seat), MTX Pro 400x5 amp, Boston RC620s front & rear and MTX 10" sealed box sub in the trunk. New headlamps with PIAA Xtreme White 9005/9006 bulbs.
Yea i already put them in. They are amazing! My mids out pound most of the people with those little cheap 8 inchers or a reallllly cheap 10". I put the tweeter right on the top of the door just infront of the little side window defrost panel deal angled a little upwards and a towards the driver/passenger. The crossover is just on hte top left of the door (looking from the inside). Had to rip off some of the support foam crap but its a very clean job. They are ****ing expensive tho! I ordered them into our store, costs us like 400 bux i couldnt imagine buying them retail lol :p . Anyways im very happy with them and i'd recomend them to anyone who wants to spend the money!
Joel Falkenberg
Moderated by  dnewma04_dup1
