Posts: 97 |
Well, do they? I wanted to get some new speakers, as because my "premium audio" ones suck big balls.
+Ford Thunderbird 1997 - V8 +Ford Contour 1995 GL [REST IN PEACE :(][Champagne|ATX] -9mm Ford Racing wires -CTA Intake Kit -Removed exaust resonator
Posts: 897 |
They will fit just fine, pull the door panels off and stick the new ones right in. I'd check the Car Audio forum for more details and specifics.
1998 T-Red CSVT (1492 of 6535) Born on 5/30/97 KKM 4.6L TB with custom "Throttle Optimizer" Bassani Exhaust NP-Tuning Sniper Intake Pipe Fog Light Mod with 885's Clear Corners Stereo - Oh Yeah!
GOLIATH - RIP 6/14/02
Posts: 1,861 |
The Pioneer 6x8 will drop in. I don't know about other brands. You can also buy (if you look around for them) speaker wire adapters so that you don't have to cut the factory wires.
Jim Johnson 98 SVT
Posts: 4,899 |
The 6x8s should drop right in. IIRC there was someone had a pair of 6x8s who said it was not deep enough but I can't remember which ones they were. BTW, if you're interested I have an almost new set of Pioneer 6x8s with rotatable tweeter for sale. TheGSRGuy@aol.com
Posts: 816 |
i have pioneer 6x8s in front. I plan on puttin' 6x9s in back, don't know how it's gonna work out though.
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 3 |
The factory speakers are all 6x8's (at least in the mondeos they are, I'd assume its the same with the contours) so you shouldn't have any trouble with aftermarket 6x8's. To be safe, you might want to take one of your door trims off just before you go to the car audio place to buy your speakers, so you can test some while you're there and make sure they're not too deep.
- 95 (HB) Mondeo LX 2.0L Zetec - Kenwood KDC-2020 head unit - Kicker 120.2 amp running JL Audio VR600-CS splits - JL Audio TR570-CX 5x7 rear fill speakers - Kicker 600.1 amp running a Kicker 12" Solo-Baric L7 sub (yes, the square ones - I am still yet to figure out how the hell they work)
Posts: 8,142 |
6x8s/5x7s should drop in. Most 6x9s will fit in front without mods, but there are a few that can't (Infinity Kappa 6x9s).
Posts: 97 |
Would all 5x7's fit, given that their depth is the right size?
Posts: 118 |
i just put infinity 5x7's in my svt(rear)they fit right in just fine,but all of the bolt holes didn't line up..i just screwed a self threading screw in the holes that didn't match up(very easy to screw into the thin inner panel)and they work just fine...a little more work,but well worth it and easy to do..they sound 100 times better than the pathetic stock speakers..and best of all i got the infinity's on ebay for $20...
98 silver frost svt no cats/magnaflows kkm true-rev white hvac ford blue calipers more to come!!
Posts: 9 |
I've got Pioneer ts6768 6X8 (just put them in today)and they fit perfectly but you do have to change the speaker connecters. They are a good clean sounding speaker (three way design cicuit city $99.
99 Black SE Sport V6 ATX K&N Filter BAT 21mm rear stabilizer bar Planning Dual exhaust, possibly Yodude Performance.
