DanS Offline OP
(Reposting to more appropriate forum...sorry)
I am having the Quaife installed and want to put in Redline oil/fluid. The Contour Owner's Guide states to use ATF fluid for both the automatic and manual. So which Redline product should I use? The D4ATF, MTL, or MT-90? I did read in the MT-90/MTL product sheet that MT-90 is used with some limited slip diffs to reduce chatter. Looking for suggestions...
Thanks,
Dan
Like what was stated in the other forum.....first 500 miles use ATF.....then (mine and demons personal prefrence) switch to redlin MTL....i have used nothing better!!!!
Roz
The diff itself isn't going to have a specific requirement, it'll run in just about anything. So you can use whatever seems best from the transaxle - so do as others have recommended...
Rick Barnes '66 Ford Ranchero '84 Ford EXP Turbo Coupe '88 Mazda 323 GTX '88 Mazda 323 SE/GT hybrid '93 Ford Aerostar XLT AWD '99 Ford Contour SVT
