The only reason I ask is because I am modeling it on SolidWorks at work, so I need an accurate number. It doesn't have to be exact, just close. The reason I am doing it this way is because I am squeezing 3 12" subs(2 facing into the cab and one facing into the trunk with amps on each side) into the rear deck. So the chambers in the box are obscure shapes and hard to calculate accurate volumes.
1998 Silver Frost SVT Purchased 01/10/02 Mods so far: -Fidanza aluminum flywheel -Clutch upgrade -Clarion ProAudio system, DSP, 13 Band EQ
Future mods: -Intake upgrade -Performance plug wires -Autolite double platinums -Konig 18 X 7.5 Toxxin's -Koni's and Eibach coil overs -Rockford amps, 3 12" Rockford subs, etc.. (Just needs to be installed)
