MattB Offline OP
I have never used my cig lighter. I was wondering how the ring around it lights up. I know it comes on when i turn the parking lights on. Does that mean the wire leading to it only works when lights are on? or is it a constant 12V?
What color wire did you use to put a LED in the door handle, i have automatic door locks. I wanted to tap into the wire that supplies the light in the button to light up.There seems to be a ground wire and about 5 others. What color is the one for the lights in the door locks?
Thanks
Matt
'97 Pumice Zetec Sport- 'At least its not a geo!'
I'm not sure about how the power supply works, but it's just a green ring that has a light bulb behind it that lights it up. You'd probably have to change out the whole ring, or try and do some color combinations to get a different color out of it.
Jonathan '96 Contour Zetec MTX 208,XXX miles
MattB Offline OP
im just looking for a power supply in that area that is alive when the parking lights are turned on, not to change colors, i have better ideas for that space
Matt
If the cig lighter doesn't have a switched power, but rather a switched ground, the radio will certainly have a switched power.
9
There's always the option of adding a relay off the headlight switch wherever you want it.
God graced us with intelligence, let's use it.
2
Its the purple wire and I think it has a yellow stripe on it on the door lock harness plug and of course tap the ground wire into the black wire.. Its the only purple wire. I did mine about 3 weeks ago and i'm very pleased with them.
Irfan Rahim irfman2000@yahoo.com 2006 Blue Nissan Sentra SE-R Spec V Former owner of a silver 2000 Contour SE Sport ATX
MattB Offline OP
I finally did it, the wire in my car was orange or dark red with a yellow stripe. Looks really good, very bright.
Matt
Matt
can i get some pictures, also a little write up of how you did it. (will supply a discount of my next GB for LEDs if you would like)
thats just for him everyone!
95 SES Sold 99 SE Sport Sold 99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
I think you might need to do my interior on the SVT!
I get nervous thinking about ripping it up and splicing into wires! lol.
Hugo ------ 98 SVT - 53k mi - SOLD 04 Mazda3 S 5-Dr
ahh its not that bad, its pretty easy, sounds hard, but its not.
