Posts: 3,774 |
i also just threw down a bid for an Alpine MRV-F353, 5 channel amp, currently at $190. 50 wattsx4 + 120w for sub at .04% THD, 4 ohms, and 14.4 volts. 4 hours left, let's see what happens....
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t 1974.5 MG B GT
Posts: 139 |
only weird thing about that dayton....a 15 inch with such a large box volume only extending down to 30 hz? whats with that
Posts: 1,032 |
Originally posted by sound_contour: only weird thing about that dayton....a 15 inch with such a large box volume only extending down to 30 hz? whats with that Price = $58 Sensitivity = 94.5dB Power Handling = 250w RMS It's just a very cheap way to put some bass in your system. It should sound good powered by only 50w or so. It rolls off pretty close to the BP1001 in a sealed enclosure. BTW, it also performs much better in a ported enclosure, and reaches into the low twenties. It's just freakin' huge at 5ft^3.
1999 SVT #900/2760 Born on 1-20-99 Silver Frost/Midnight Blue A few aesthetic and audio mods
Posts: 3,774 |
i didn't get the 5 channel amp, outbid at the last second.
but i am looking at getting another MRV-F250 and a pair of Alpine subs.
let's see how THIS one goes... :p
Posts: 411 |
Whatever you do, don't buy a diamond audio subwoofer. My friend has one and it sounds like crap compared to my pwd 254(mb quart). ALso, the seal has blown once, the coil has blown once, and something esle blew on it.....she is on her 4th diamond audio sub under warranty....she just got an eclipse and said screw diamond audio
99 Tropic green svt Custom Stereo borla cat-back 22mm bat rear sway bar custom K&N & heatshield 215/40/ZR17 Rubber jimmkreider@yahoo.com
Posts: 30 |
try an Xtant A10" sub they rate 350 watts and use about 1ft cubed in a single ported box. They are MTX's high end for all around sound. Not just SPL.
Posts: 8,142 |
Originally posted by sound_contour: only weird thing about that dayton....a 15 inch with such a large box volume only extending down to 30 hz? whats with that They went for sensitivity. In any sub you can have 2 of the following. Small Box Low freq extension Effeciency Dayton decided to concentrate on a small box with high effeciency and thus, lost deep bass. But with cabin gain, it would still produce very deep bass.
Posts: 1,083 |
Originally posted by 99badsvt: Whatever you do, don't buy a diamond audio subwoofer. My friend has one and it sounds like crap compared to my pwd 254(mb quart). ALso, the seal has blown once, the coil has blown once, and something esle blew on it.....she is on her 4th diamond audio sub under warranty....she just got an eclipse and said screw diamond audio :rolleyes:
1998 SE ATX Dual exhaust Body conversion Nakamichi CD-40z HU Sound by Crystal Mobile Powered by a/d/s M860 AMP My Ride
Posts: 3,774 |
that blueprint 1002 in a sealed box looks like a really good option. are they 4 ohm or 8 ohm?
Posts: 3,774 |
the search is over. i just got a pair of Alpine SWE-1014 10" Type-E subs for $120 including shipping. since they retail for $100 each, i thought this was a decent deal.
.6 cuft per speaker and i'm sure i'll be happy.
still bidding on another MRV-F250 amp to power them....
thanks for your help!
