Originally posted by ARJoel:
Infact it is probably Bad to put home audio into your car. Home audio usually runs at 8 ohms while car audio usually runs at 4 ohms. Unless you find an 8ohm stable amp of course. But if not it will reduce dramatically the life of your home audio speaker and amp.
Well, the impedance isn't what would be an issue. I would just question spending thousands to put some monitor speakers in your car, when you can spend hundreds and probably get similar sound. The impedance would only affect the output of the amp, it wouldn't hurt the speakers or the amp in any way.
