PTAaron Offline OP
What size bushings do I need to get to be able to put my stock bar back on using the brackets that come with the "aussie bar"? I know this is a double post - but in the SE MI forum all it did was start a discussion about bar itself instead of answering the question - maybe someone here knows the answer
-Aaron 1999 Contour SVT #2553/2760 Order protein powder from www.trueprotein.com and use AAL229 to get 5% off!
BAT sells bushings. The bar is 19mm if a recall? Go on BAT and look under the suspension parts. I don't know if they'll work in the aussie bar mounts..but they might
06 GMC Sierra 2500HD Dmax/ally 06 Pontiac G6 GT 05 CRF250R FOR SALE 06 KX65 with riding gear $2700 obo
PTAaron Offline OP
Thanks... I would go back totally stock but I had the "upgraded" plates welded on so I have to keep using the brackets that came with the bar...
F
F
Damn it if I didn't forget the companys name who sells the bracket/bushing combo that was included in ever Aussie bar purchase.
I assume your mounts are U shaped, bole up on each end adn you have a red urethane busihing that is grooved?
If so, you can go to said company and buy a new bracket/bushing set. $15 shipped I think or inquire about new bushings for the Stock SVT 18mm bar or whatever size bar you are using now that will fit the U bracket you already have. All there U brackets come in two sizes. Type A or Type B. The bushing cutout size changes but not the bracket size.
I hope that helps!
You're probably thinking about Prothane bushings and I think that Summit Racing my sell them, although I can't remember for sure.
George Hodge New: Volvo S60R Old:2000 SVT Silver Frost 1188/2150 DMD, 75mm Pro-M, HPP rear strut tower bar Aussie 24mm sway bar (with boxed in subframe) BAT European Handling Kit, Brullen Y-pipe Performance Ford spherical bearing end links
PTAaron Offline OP
Good info guys, thanks!
