Posts: 184 |
hey whats up , i have 2 10" kenwood subs in my trunk, and recently after having them pumping for a while, they seem to shut off.. ...then after like 5 min they will go back on...could this be the wires doing this???? what can i do to fix this...it is really annoying especially when they just shut off and a good song is on..lol...ive had them for about 2 years now...thanx
Chris
99 V6 Sport/Silver
SVT kit~SVT Dual Ex.~KKM intake~Front & Rear grills painted silver~GTS Headlight covers~Plasma Blue light under dash(removed white bulb)~30 % tints~Tinted Rear Reflector~Wood Grain Kit~Removed door dings~Super White Heads~Plasma blue reverse lights~ blacked out sail panels~painted brakes Blue~complete stereo system~
Posts: 613 |
could it be the amp overheating, I know I have a punch 400 with 2 12's and if I have them up and back seats are in place like supposed to be, they will do that, so when I want to have them hitting hard, I fold down the back seats, which gives more bass up front along with airflow to the trunk cooling my amp.
~~~~~~~~TRAVIS~~~~~~~~ Now driving: I MEAN NOT DRIVING---- 1995 Contour SE Maroon, MTX, sunroof w/rain-guard, neons, and audio replaced. Side Markers installed and headlight strobes also now on. *KKM tru-rev - I love it 9mm FMS blue wires SVT Upper SVT exhaust SUPERCHIP˛ custom ram air Newest mod = f***ed up engine, prolly shot, yeah
Posts: 91 |
Recheck your grounds on your amp. It could be a loose connection or a bad ground causing your amp to shut off when it shakes loose or is takin to much power. I had a similar problem (my friend made a half-assed ground) and when i finally went back there to check wtf was goin on there was a hole in my carpet and the ground was very loose lol. Something i've learned is if you don't do it yourself, dont expect it to be done right.
Joel Falkenberg
Posts: 184 |
thanx guys...ill have to check that out asap....
Chris
99 V6 Sport/Silver
Posts: 20 |
My best guesses are: #1 over heating #2 over heating #3 remote line (test the wire w/ a multi-meter for continuity, its so fragile) #4 bad (lose) amp ground wherever you attached it
Posts: 108 |
I'd say overheating too, My fosgate amp turns off for 30sec-2 min at a time. They get REALLY hot.
White 00' Mercury Mystique GS Aiwa CDC-Z117 CD Deck Rockford Fosgate 160.2 Amp Two 12" Lightning Audio Subs in Sealed Box. 5% tint
Posts: 85 |
definately overheating my Hifonics amp used to do the exact same thing
2000 SVT #1633/2150 many mods, many more to come http://www2.gvsu.edu/~hafnerb/11h/car.jpg "If it doesn't fit, force it, if it breaks, it wasn't meant to fit in the first place."
Posts: 184 |
damn overheating...sh$tballz...i figured it was that...oh well...i guess for a few min. ill have to turn it down a lil...  ...thanx guys...
Chris
99 V6 Sport/Silver
Posts: 125 |
I'd say its time for a new amp and a proper install. Thats nuts having to let your amp cool down.
CM.
99 Mercury Mystique V6 Black KKM, 9006 BV Bulbs, Painted Calipers, 16" Cougar Rims Alpine 7894, CDT HD62DT front, CDT Coaxials rear, ,Mmats Pro 10's. POS amp. No RICE.
Posts: 184 |
it was properly installed...and i have had the amp for some time now...but it does overheat, especially if its 95 plus outside...but all in all ill have to do something about it...
Chris
99 V6 Sport/Silver
