Page 4 of 7 1 2 3 4 5 6 7
Q
qaz Offline OP
Q
And, as I mentioned in that thread, their letter whitewashed the situation. The impression I got was that unless there are obvious bare wires under the hood, nothing is wrong. Did that guy really think that the dealer was going to tell me that the harnesses needed to be replaced when nothing was obviously wrong?
I'm sure that, had I made enough noise, I could have gotten them to replace the harnesses, but I thought only some cars were built with the wrong insulation, not all of them, and the assumption I made was that if the harness wasn't cracking it was going to be fine.
WRONG. My '96 doesn't have any obvious cracking, but I'm going to raise hell with the dealer until they replace the harnesses on it.
Brian
Originally posted by MystiqueSVT:
Wow...what a jerk! Ford knew all along about this issue and kept it hidden knowing full well when most found out about the recall, it would be too late....as in my case!!
Lee Offline
Brian, One recommendation about the recall I can give you is take out your battery and look at your positive battery terminal wiring. Mine was completely corroded off. If you show them this they have on choice but to replace it as that's in the recall documentation.
Also as far as My IAT connector goes it looks like the one you have a pictue of. Not exaclty like it but very close. Is there a place that I can get a pigtail assmebly or do I need to go to Ford for this?
Lee Cox
In life begins responsability...
Project Car
Q
qaz Offline OP
Q
I don't know of any place that you'd be able to get a pigtail for that other than the wrecking yard.
The Ford dealer is going to want a part number for the connector sleeve; getting the terminals is another can of worms.
If the connector sleeve isn't damaged but the terminals are, they MAY be able to find replacements in the 4-box kit (they come with 4" of wire pre-attached, for splicing into the harness).
They'll need a terminal to match it up, though...
Brian
For all those who have this issue with the underhood wire harness, I encourage you to go here The NHTSA has the power to force auto manufacturers to do a recall with no cost to the consumer if they get enough complaints. I have filled out a form and I suggest all on this board do the same.
95 Mystique LS Young America edition, V6, MTX, Yeah...it's stock. Now with new underhood wiring!!! My Profile
Moderator of the Florida Contour Enthusiast Group
Spoke with 2 Ford mechanics at the Tallahassee autocross who said that wiring harnesses are a known problem on V-6 Contours. They brought it up, not me.
On a positive note, they had good things to say about the Focus. Maybe early teething problems. But I did hear the whole story about their guy who rolled a Focus at our divisional event in 2000. In a steady state turn and car left the ground completely, landing on roof and then on opposite side. Guy was trying to do a class-action lawsuit and then tried to hit Ford up for racing sponsorship. Don't know if he was stupid or just trying to blackmail them. :rolleyes:
On a related note, a lowered, sway-barred new VW Beetle gets up on 3 wheels in a scary fashion!!
Fastest Contour at SZ 2002 Auto-X. 10th in PAX out of 125. CEO of FOGEY(Fast Old Guys Emasculating Young-uns), Inc. Terry Haines, Chairman, Senior V.P.s: (alphabetical)JavaContour, Jet Mech, MFE, SeicoRacing, SVTSTS, Vern Kilburn. If your not a member, yet, wait a few years. I'm not just the CEO, but I'm a member, too. Working with the rank and file to get the job done right!
Historical:
63 TVR (1K in 74), 75 TR-7 (paid cash new), 79 RX-7 (zoom,zoom), 81 RX-7GSL (autobahn-driven),82 Mustang GT (autobahn-driven), 85 Mustang GT (SE Division F Stock Solo II Champ), 86 MR-2 (3rd SE Division D Stock), 88 Civic DX (had 1st born and still owned MR2) 92 Sentra SE-R (all go and no show), 98 EO SVT Contour (FTD SZ 2002). 02 Altima 3.5SE 5 spd!!!
Q
qaz Offline OP
Q
Maybe we need a website set up specifically for information about this problem?
Searching for "ford contour wiring cracking" on google doesn't get anything related, and there is not much information about this problem on the net at all.
Brian
Brian
[b]For all those who have this issue with the underhood wire harness, I encourage you to go here The NHTSA has the power to force auto manufacturers to do a recall with no cost to the consumer if they get enough complaints. I have filled out a form and I suggest all on this board do the same.
[/b]
Ok...well...go here. Type in for example, 1995, Mercury, Mystique, then select electrical-underhood wiring harness. You will see 15 consumer complaints.
1996=8 complaints.
1997=3 complaints.
Now type in the same for a 1995 Contour. You will get 39 complaints.
1996=9 complaints
1997=7 complaints.
Most of these complaints had fires associated with them.
If you search a little further...you will find all kinds of information.
I cannot stress more strongly the fact that everyone needs to do this. Maybe Lance will help us out by getting a special link or page together.
okay dumb quiestion time:
is the underhood wiring harness the 'only' one referred to as 'wiring harness'???
the reason i ask is that i was reading over my warranty info last nite and came across under covered items, THE WIRING HARNESS!!!
and if also says that if they cover something thta is also covered by ford or should be that they will either pay for the repairs needed and/or go after ford to reimburse them... laugh
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
Q
qaz Offline OP
Q
A wiring harness is an assembly of wires, designed to connect multiple circuits.
By that definition, almost every wire in your car is part of a harness.
Brian
1
1
Does this apply to that battery wires too? The insulator on mine is stripped... What should I tell those service people at the dealership when I go there?
UBRF.org , Western New York's Premiere Automotive Forum.
Yeah, I got some bolt-ons.
Car Pics
Video of Brullen cat-back on a \'95 SE
How-to: Short Shifter for Pre-98 MTX
"heres the deal $2 grand buy in winner gets the cash and the girl and the respect. We'll race from 0 to Inf. until I win." - someone on the internet
