#916278 04/01/04 02:10 PM
Steeda Offline OP
I am looking into getting a wider tire for my 2000 Contour Sport V6. The factories are 205/60R15. I have researched it and a 245/45R16 will be the exact same diameter as the 205's, but obviosly wider. The question is will a 245 width fit with minimal or the preferred no rubbing in sharp corners? Also will that tire fit correctly on a 16x6 Ford Racing SVT rim? Please advise.
Thanks! Rob
Rob Mission 2000 Contour Sport V6
#916279 04/01/04 06:41 PM
I can't see a 245 tire fitting on a 6" rim.
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
#916280 04/02/04 03:58 AM
H
H
i definitely dont see it happening. the most some guys are running on here are 235/40 and that might be on at least a 6.5inch wide wheel if not at least 7 inch or more. 225 on the stock 16 x6.5 already shows a buldge in the sidewall.
#916281 04/02/04 11:25 PM
Y
Y
I have 225/45/16's and they have NO bulge.. I think the guys running a 225/50 might show some bulging due to the 4x4 looking sidewalls.. But a 245/45 will be a monster truck tire man. you have to realize that the "45" is the percentage of the width(which is 225 millimeters) so that means that your sidewall is going to be too large, and the 245 width on a 6.5" width rim will be scary.. Good luck!
And why do you want such a wide tire?
Mark
#916282 04/03/04 01:09 AM
E
E
Because it looks good.
Anyway, here is another thread on it that I had bookmarked. Apparently Buckshot has already done it. Clicky!
· Jon Miconi · Coming Soon! · 01 Cougar · 98 V70R
#916283 04/03/04 02:17 AM
2
I just put 245-50-16's on my 7" tbird rim and there is quite a buldge so you'd almost have to go 245-45-16's on a 7.5 or 8" rim if you could find one
Derek Johnson 88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3 95SE 3L gone
#916284 04/03/04 02:20 AM
H
H
but buckshots wheels arent 6inches wide. the ssr's have to at least be 17x7 i'd imagine
#916285 04/03/04 02:21 AM
2
16x7 you mean
#916286 04/04/04 10:39 PM
H
H
16x7 you mean
no i dont. the original post was asking about a 6inch wide wheel w/ 245. i was saying buckshots ssr's arent 6 inches wide. he did a 245 on a wider than 6inches wheel.
#916287 04/05/04 04:37 AM
2
the 17 part is what I was questioning, the were 16's
245-45-17's would never fit.
Moderated by  1314_dup1
