Posts: 385 |
I remember seeing a pic a while ago of someone cutting a new hole to run their speaker wire to their front doors. Does anyone still have a pic of that? Thanks, -Matt
Posts: 4,639 |
look in my sig in the pics folder
Hugo AIM:omegazodiac
Posts: 54 |
can I just use a regular household drill to do that
Posts: 385 |
Hugo, thanks alot. I did the same thing, however I did it before I found your pic. Thanks tho, -Matt
Posts: 1,359 |
98' Contour SVT
#607 of 6535
05' Mazda 6s
Audio/Visual enthusiast because it's one of the many things I went through 4 years of hell for
Posts: 4,639 |
Originally posted by Tj78492: can I just use a regular household drill to do that
yes but i'd recommend using unibit drillbits. i started a pilot hole with a pretty small drill bit then switched to the unibit for a clean hole
Posts: 4,639 |
if u need speaker wiring i have some. i'm pulling the 12 gauge from the front doors to run 2 more 16 gauge lines for a total of 3 16 gauge to each front door (i'm planning on a 3 way front stage). the 12 is gonna make it too thick. if your running coaxials or or separates with passive crossovers, it'll be great. i believe i have enough for the rear doors too. i decided not to amp the rear doors so i dont need the wiring.
Posts: 511 |
hmouta....i have a question about your positive battery connect. What is that connector piece that goes into the 4 guage hole....when looking at the top of the positive battery connect, the the connector attached on the far right, I had a hard time getting the thich wires that were attatched to that positive plate on the stock positive connector and it came out real messy. Can you walk me through your setup because yours is very clean.
AIM...BKapp17
98 T-red SVT
Steeda
Gutted Pre-cats, no resonator
Painted Dash
Angel Eye Fogs
Painted Chrome ring / headlights
Looking for a t-red pre98 trunk lid
Posts: 4,639 |
that connector thing is a lightning audio 0 to 4 gauge adapter so the audio line goes to the 4 gauge in on the terminal and the 0 gauge for the battery dist block goes into the 0 gauge. i'll tell u this. mine were a huge [censored] to do also. i actually dremeled out the 0 gauge on the terminal to increase the diameter to get the 0 gauge wire in and "shaved" some 0 gauge wire strands to get it more compact. i also dremeled the hole on the terminal where they sit on the battery post so the terminal would sit all the way down.i did it a hair too much. they are very slightly loose, but not enough to shake or slide around at all. maybe each car is different but i had to dremel alot out of the battery box to get the battery down and to the far left as much as possible. my neg terminal started to hit the hood slightly so i had to do some more dremeling to the box and needed to turn the terminals more counterclockwise to get the mass of the terminals away from the downward slope of the hood. there's a pos and neg dist block screwed into the back of the batt box. the stock wiring was a pain in the a$$ to get to fit right but its very doable. i can visibly see my inline fuse holder and easily change the fuse if it blows. its within 18 inches. i couldve put it dangling under the air box but then had to remove the airbox just to check if the fuse is blown and/or change. i wanted it to look good, be functional, and userfriendly. to prevent the battery from possibly sliding around, i got some pipe insulation wrapping tubing and cut it to fit into the open space to the right of the battery. there's 3 pieces used and each one has strips of the insulations stuffed into the middle of the tubing to make it more solid to hold the battery in place. the terminals plastic covers i keep on all the time. i drilled holes where the hex gold screws stick up so the covers can sit down on the terminals properly. so far everything has worked perfectly. it honestly took me about 3 days to get the right fit and finish. this included the wiper cowl removal, running the power wire, and lots of dremeling and trimming the wiring a little at a time. i cut out a slanted piece from the battery tie down to allow the 0 gauge to sit down and not get crushed, again, i had to turn the terminals for clearance. the hood grazes the neg plastic cover but nothing to creat a dimple. up next is upgrading the grounds to 0 gauge and running 0 gauge to the alt
