#91301 06/12/02 09:15 PM
I am installing a 1000w kenwood amp. I hooked it up but it keeps losing power. I need to reground it cuz not enough power is going through. its currently grounded under the trunkmat on the chassis rail. Anyone know better place to connect the ground wire? I tried looking for a TORX bit to remove the seatbelt buti cant find one that big. help!!! i wanna hear my new system bad!!! confused
99 Ford Contour SE
2 12" kenwood subs,1000W kenwood amp, Pioneer Head dehp7300, RF 5" Components (f), pioneer 6x8, Dynamat, K&N filter, aftermarket foglamps, side markers
#91302 06/12/02 09:28 PM
Passenger side rear tirewell area, SVT's have a nice power antenna you can ground to (two large screws, no drilling or hardware required and its a hex head bolt wink )
#91303 06/13/02 02:47 AM
it wouldnt work on non-powered antennas would it?
99 Ford Contour SE
#91304 06/13/02 06:17 AM
I never looked at my 95 to see if the same mount is there. Look where the antenna is, right below it near the floor, there should be two holes perpendicular (sp?) to the floor where a power antenna would mount.
Moderated by  dnewma04_dup1
