Originally posted by JOHNE:
Just bought the p80.4 for $130.
now to go with Dave or Tony hmmmmmmmmm
What's the benefit to making my crossovers as opposed to buying some like the ones Tony suggested?
JE
Making you own will allow you to use the components I suggested. You can use the actual specs from the speakers to build your own. I will be posting some pics shortly of some home grown crossovers I built.
Keep this in mind...If you have a 500.00 set of components, 50% of that is retail markup (less if bought on line so will will go with 35%). So now, the mfg charges the retailers 325.00 to buy them. They are also making a hefty markup, lets say 50% over material costs) now the component set costs 160.00 drivers and crossovers to build. What I am trying to show is if you take some of the markups out of the equation, things can get very affordable. This is why I'm a big DIY fan. The soundstream Exact components ranged from about 300-400.00 depending on size. You could buy the mid for 35.00, the tweeter for 25.00 and the crossover for 15.00 from parts express.com. 150.00 total....
With proper integration, the Hi-Vi/Morel combo has more potential but will require some tweaking. For ease of use and drop in performance, Tony's suggestions are probably the way to go.
Here are some good acoustic calculators.
http://64.176.254.129/Groups/Tech/AcousticsCalc.htm
