A common problem with headlights is that they "haze" or "yellow" over time and/or "spiderweb" or crack. This is the UV coating deteriorating.
The headlights are coated with a UV film/protectant of some kind, and constant exposure to the elements (sun, rain, snow, etc.) deteriorates the UV film/protectant which results in the yellowish haze that develops.
Approach the UV coating just like you would the clearcoat on your paint.
If it is physically damaged, as in cracked or scratched, you have to remove the coating down below the defect. Then you can restore it.
Below is a "How-to" compiled from personal experience as well as using the
Search to see how other CEGers tackled the problem.
This pertains primarily to 98+ headlights, but should also work for pre-98 as well.
The easiest way to prevent this from occurring is to wax your lights every so often.
I wax my headlights every time I wax my car (every 3-4 weeks), and my headlights look brand new after 3 ? years.
Now, if your headlights have already hazed over, you have several options:
1. Buy new headlights ? obviously the most expensive way. But the easiest way out.
Contact:
Bill Jenkins
www.SignatureLM.com
parts@signaturelm.com
800-876-3280 x272
Be sure to tell him you are from CEG to receive the CEG discount.
**Use the following instructions at your own risk.**
2. Use a plastic cleaner and plastic polish
If your headlights are not too hazed over, this should be your first step prior to resorting to sanding (Option 3).
This way you are starting with the least abrasive method of removing the haze before using anything more abrasive such as sandpaper.
Several CEGers have successfully used plastic cleaners and polishes to remedy the hazy headlights.
Some products used:
Meguiar's PlastX Clear Plastic Cleaner & Polish
Meguiar?s Mirror Glaze Clear Plasitic Cleaner #17
Meguiar?s Mirror Glaze Clear Plastic Polish #10
Meguiar?s Clear Plastic Collection is only a few dollars more than purchasing just #17 and #10 individually.
3. Wetsand the headlights
Many CEGers have successfully used similar methods as the one below.
What you will need:
- 1000 grit wetsanding paper ? available at most auto stores
- 1500 grit wetsanding paper ? available at most auto stores
- 2000 grit westsanding paper ? available at most auto stores
- small bucket or spray bottle with water
- car wash soap
- sponge
- rags
- wax
- applicators
- Meguiar?s Mirror Glaze Clear Plasitic Cleaner #17 & Polish #10 ? Option #1
- rubbing compound ? fine cut & polishing compound ? Option #2
* Note: You want to take your time and be as thorough as possible through this process. You don?t want to have to start all over again or repeat steps because you skimped on a step or two.
1. Wash
Wash your headlights to remove all dirt, debris, etc. You want the headlight to be clean. Dry them off and examine them, noting the areas that contain the most haze. These are the areas you will need to focus your wetsanding. Give those areas a feel with your hands to see what the haze feels like.
2. Remove headlight (optional)
You may want to remove the headlights from the car ? this will allow you to avoid accidentally sanding the paint on your car, and it allows you to place the headlight in a more comfortable working surface.
3. Water
Use the bucket or spray bottle of water to dampen the headlights, and slightly dampen the sandpaper.
4. Sand
Use the 1000 grit sandpaper and begin sanding. Be sure to take your time and be thorough, especially in the areas with the most haziness.
**Sand in different directions - horizontally, vertically, etc. to get the best sanding "coverage".
You?ll probably be nervous about using sandpaper on your headlights, but rest assured, they will come out better looking than when they were hazey.
5. Rinse
Rinse off the headlight and examine them. You should see fine ?scuffs? and ?scratches? from the sandpaper, but again, don?t worry. Feel the headlight ? they should feel smoother than before.
6. Sand
Move onto the 1500 grit sandpaper and begin sanding. Be sure to take your time and be thorough, especially in the areas with the most haziness.
7. Rinse
8. Sand
Use the 2000 grit sandpaper and begin sanding. Be sure to take your time and be thorough, especially in the areas with the most haziness.
Take your time. This is the final stage of sanding, so you want to be thorough as you do not want to have to go back and repeat this process again. Rinse, dry, observe (visually and with your fingers) areas that need to be further sanded, and sand.
9. Wash and dry
Wash and dry the headlight.
* Now you have 2 Options at this point:
Option a:
10a. Rubbing compound ? fine cut
Use some type of rubbing compound to smooth out the sanding marks. Do not use a heavy cut/coarse rubbing compound as it will only add scuffs/scratches.
11a. Polishing compound
Use some type of polishing compound further clean up the surface and give it a shine.
* If you have a buffer handy, you may want to try using it instead of applying the compounds by hand.
Option b:
10b.Meguiar's PlastX Clear Plastic Cleaner & Polish
OR
10b. Meguiar?s Mirror Glaze Clear Plasitic Cleaner #17
Removes any fine swirl marks / fine lines.
and
11b. Meguiar?s Mirror Glaze Clear Plasitic Polish #10
Restores the shine on the surface of your headlights.
**You can use Option a, then use Option b afterwards.
12. Wax
The best way to prevent hazing of your headlights is to use some kind of protectant.
I would recommend waxing your headlights whenever you wax your car to provide them with protection from the environment.
* One CEGer stated that Carnuba wax will "yellow" clear plastics over time, and should be avoided on the headlights.
13. Reattach headlight if necessary
14. Repeat for other headlight
Other "Methods"
drerok: rub your headlights with Automatic Transmission Fluid
Kremitthefrog: rubbing compound every 6-9 months
Phil Rohtla: Another way from MustangWeekly.com:
Light kit
Proof thÿ
