speersy Offline OP
Does anybody got a manual for a 96 mystique that they don't need?
I have a french copy but I dont understand any french.
I need to know the fuse & power box fuse locations.
Also need to replace adjusters on headlights.
Ford wants 180. skins for one headlight assembly but all i need is the adjuster unit. Has anyone replaced a light and kept the assembly?
Will try the wreckers But they were closed.
If anyone can help, it would be much appreciated.
I am Canuckian
I am Canuckian
Is the lens damaged or just hazed? As far as the manual goes. For sure try a wreckers. Or better yet pick up the Haynes manual avaiable @ Canadian Tire. Call around to make sure they have one first. If you get stuck let me know what fuse locations you are looking for and one of us could surely look in our own manual. I beleive all the pre 98 Contiques have the same wiring. It wasn't till some of the later model did they change the wiring and I think that is only the case if you have a fuse box with mini fuses.
Also to reset the computer I remember that I pull fuse number 4 and 11 under the hood if that helps.
Green 96 mystique gs 4cyl mtx 16.9 in the 1/4 mile @102500 miles 95SE in Midnight Red MTX MSDS headers and y-pipe SVT exhaust SVT UIM Optimized se TB. Full pre 98 SVT body kit 15.741 @ 87.73mph :)
speersy Offline OP
I will never buy a Haynes manual again! Even my mechanic friend says they tell you everything you don't need to know and nothing you need. The Haynes manual doesn't have the corect fuses for my car.
I'm looking for the fog light fuse.
I am looking for a mystique\contour at the wreckers but I only have found one in Cambrige Auto Wreckers but it has had most usable parts stripped already.
I will try again next weekend but I thought I would try here
to see if someone might have what I need just in case.
The head lights are slightly hazed because the coating is starting to peel but I am only looking for the adjuster mechanisms (adjuster screws) which will popout if pried gently but ford will only sell the head light assembly.
T tryed to fix it but it is beyond repair.
H
H
Ford manuals let's you download a copy.
Great link Doug, that's awsome.
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
I am Canuckian
I am Canuckian
Way cool.
speersy Offline OP
excellent! thanks
Thanks a bunch! :-)
Kyo 1997 Mystique GS Duratec ATX -- sold 2005 Focus ST - Quicker! - Still a Duratec!
Moderated by  Gerald_dup1, mbb41_dup1
