I will never buy a Haynes manual again! Even my mechanic friend says they tell you everything you don't need to know and nothing you need. The Haynes manual doesn't have the corect fuses for my car.
I'm looking for the fog light fuse.
I am looking for a mystique\contour at the wreckers but I only have found one in Cambrige Auto Wreckers but it has had most usable parts stripped already.
I will try again next weekend but I thought I would try here
to see if someone might have what I need just in case.
The head lights are slightly hazed because the coating is starting to peel but
I am only looking for the adjuster mechanisms (adjuster screws) which will popout if pried gently but ford will only sell the head light assembly.
T tryed to fix it but it is beyond repair.
