Posts: 121 |
Ive replaced the plugs with the platnuim plugs(it quit missing for about a week, then started again)done the magnacore wires,and replaced the coil......What should i look at, or change next? Could it be the plugs again?they didnt look bad when i changed them the first time......
Rusty
'00 silverfrost SVT
'99 black SVT
'86 black SVO
'86 red SVO (for sale)
Posts: 2,017 |
Do a fuel system pressure test as the fuel pump could cause misfires. Cam shaft position sensor also is the sensor that detects the missing. If you have a CEL get it read so you know which cylinders are missing.
1996 2.5LT V6 Contour ATX My Tour+help/info pics
E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
Posts: 432 |
Originally posted by ibjamn: Ive replaced the plugs with the platnuim plugs(it quit missing for about a week, then started again)done the magnacore wires,and replaced the coil......What should i look at, or change next? Could it be the plugs again?they didnt look bad when i changed them the first time......
I put in new platnuim plugs in mine...ran like crap...put in a new set from Ford, like suggested here by other people and it ran great, it was missing badly with the Platnium plugs...guess these cars don't run well on them.
Posts: 287 |
I put in AutoLite Double Platinum plugs about a month ago and have had no problems...
Posts: 121 |
Originally posted by Taasman: Originally posted by ibjamn: Ive replaced the plugs with the platnuim plugs(it quit missing for about a week, then started again)done the magnacore wires,and replaced the coil......What should i look at, or change next? Could it be the plugs again?they didnt look bad when i changed them the first time......
Thats what I put in was the double platnuim plugs...Think I should try plugs again?It did quit for about 2-3 weeks after I changed them....Or fuel pump?
Rusty
'00 silverfrost SVT
'99 black SVT
'86 black SVO
Posts: 247 |
possible bad fuel injector
EO 98 CSVT, black, gunmetal exel 18s, H&R springs ,custom grilles, 35% tint,Hightower headlights,resonator removed,Magnaflow installed,FMS 9mm wires,K&N,Redline MTL
2000 Impala silver 2 inch drop 17 inch Exels
Posts: 121 |
Oh yea, it only does it under load...getting on it or when you need to down shift...
Rusty
'00 silverfrost SVT
'99 black SVT
'86 black SVO
Posts: 2,097 |
Mine missed with the double plats...i talked to Keith at Street flight...he recommended trying copper and just replace them often...put in some autolite coppers...runs great now. I know people will disagree, but I rather have no miss with copper than miss with double plat.
98 E0 SVT with some stuff
Posts: 2,725 |
maybe your coil pack, plug wires
Posts: 121 |
Originally posted by HITMANinMI: maybe your coil pack, plug wires
I already replaced those.Magnacore wires and a new coil....
Rusty
'00 silverfrost SVT
'99 black SVT
'86 black SVO
