#90887 06/03/02 02:53 AM
I
ibub Offline OP
I
Can anyone make some recommendations for upgrading the door speakers in my 99 SVT 'tour? Don't need a super loud or bassy set-up, just want to hear a little bettter with the moonroof open, windows down, and zipping down the highway. Am considering the Pioneer TS-a6867 or Kenwood KFC6808, both are available for about $60.00/pr. Thanks
#90888 06/03/02 03:24 AM
You'd probably notice a better improvement by swapping out your head unit with a nice aftermarket deck (and stock amp bypass).
The stock speakers are alright when driven by a nice aftermarket deck. It's the crappy factory amp with its high distortion and low power output that's the problem, which will still exist with a speaker swap.
But, if you've already swapped out the HU and performed the factory amp bypass or you just want the factory deck, either speaker you suggested would be fine. I'd probably choose the more efficient of the two if you're running them with the stock HU/amp.
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
#90889 06/03/02 03:34 AM
I have the Pioneer 6857 which are 2 ways, just guessing the 6867's are probably 3 ways. The 2-ways sound good and have a good range. Since they handle 50 watts RMS they matched my 50wattx4 sony head unit. I would recommend upgrading head unit and speakers, because you would probably either over-power stock speakers(22 watt RMS) or underpower aftermarket speakers. Check out efficiency and what wattage they are. Higher efficiency can run on lower watts. Match up speakers with head unit, so they're not under/over powered. Need more advice? Talk to someone at a electronics/audio store and go to www.crutchfield.com , though don't buy from them(too expensive).
"Wow, that sank fast." "Yeah, like a rock."
96 Contour GL ATX
9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned
Sony CD player: 50wattsx4;remote;
Speakers=50 watt Pioneer 6x8s
Ross Evans smile
#90890 06/03/02 04:28 AM
Having just gone through this very thing I would say do the speakers first. I put a Nakamichi HU in my car first through the stock speakers. There was absolutaly NO difference in sound qaulity! Last week I just got around to installing my new speakers and man what a difference. I then out of curiosity I removed the Nak and reinstalled the factory HU, it still sounded great. The stock speakers are the biggest joke I've ever seen. They are made out of PLASTIC! The frames are plastic and they have no tweeter, only a whizzer cone. They are the cheapest things I've ever seen. I can not beleive Ford has the balls to call this crap a PREMIUM SOUND SYSTEM! frown laugh
#90891 06/03/02 11:48 AM
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
Sound by Crystal Mobile
Powered by a/d/s M860 AMP
My Ride
#90892 06/03/02 03:06 PM
Did you bypass the factory amp when you installed your Nak HU?
1999 SVT #900/2760
Born on 1-20-99
#90893 06/03/02 03:57 PM
Premium speakers are same as normal speakers. What is the purpose of dual cones? Powered tweeters make sense, but dual cones just seem like a waste of material.
96 Contour GL ATX
Ross Evans smile
#90894 06/03/02 04:01 PM
Finally got the speakers installed, eh? I was wondering when you were going to get that done! smile
#90895 06/03/02 11:22 PM
I
ibub Offline OP
I
Hey, thanks to all contributors for your opinions. I do intend to upgrade the HU as well, and wondered which to do first. Last complete install I did was in a '76 Camaro when it was new, so I've got some catching up to do. :rolleyes:
#90896 06/03/02 11:37 PM
swap the speakers first!
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
My Ride
Moderated by  dnewma04_dup1
