#908523 03/24/04 04:06 PM
athos34 Offline OP
My scanner (Alex Pepper) shows a TPS value of 19% at idle and also at the key on postion. There are no codes because it is still within operating peramiters. The car runs fine and the throttle linkage is on the stop. I was wondering if this is a normal idle value. Also I am curious about other normal scan tool readings at idle. I own a 96 LX V6 ATX with no mods.
#908524 03/24/04 04:10 PM
You see, its just that we're putting new cover sheets on all our TPS reports.
The Spickle New Car: Infra Red '04 FSVT Former Car: Black '98 CSVT, #3137/6535 "The Unluckiest car.. ever"
#908525 03/24/04 08:48 PM
H
H
Ummm... yeah....
Seriously though I don't know the answer, but I can find out tonight when I go home if no one else knows.
#908526 03/25/04 02:10 AM
Values around 20% are just fine and normal at idle.
Steve
#908527 03/25/04 02:49 PM
athos34 Offline OP
Dosen't 20% seem to be a little high for a closed throttle situation? In my confused mind this would be like pressing the gas pedal down 1/4 and leaving it there.
#908528 03/25/04 03:53 PM
I've just checked it in the Ford Service Manual:
The normal range of the throttle angle measurement for the Throttle Position (TP) sensor is 0 to 85 degrees.
The graph they give shows that 0 to 15 degrees is considered IDLE and 76-94 degrees is considered WOT.
If 85 is 100% then 20% is 17 and 19% is 16.15 so indeed is's slightly high, but it's nothing to worry about.
If you want, replace it for your peace of mind, it costs about $20-25 and easy to replace unless you have a 95-97 Zetec.
Tiv
#908529 03/25/04 04:55 PM
No, this is what is supposed to be.
Leave it alone.
Steve
